G'day again fellas
OK, a bit more information about what I am modelling here.
Iserlohn in Germany's Ruhr was apparently the only town of any size in the Ruhr to surrender without a fight in 1945. On 16 April 1945, the survivors of Schwere Panzerjaeger Abteilung 512 surrendered in the town square.
The photo below, which is copied from Panzerwrecks 3, showns three Jagdtigers lined up in the square prior to the official surrender. They are, from furthest to nearest, X8, X2 and X1.
The photos below show more detail of X2, which is identifiable by the five kill rings around the barrel and the shell hit on the nose which has failed to penetrate.
There was a fair load of personnel on board prior to leaving the square, including one US soldier whose helmet is just visible at the back.
After leaving the square, X2 is shown from the rear, and a couple of points worth noting:
* No RHS mudguard (there isn't one on the front either)
* LHS mudguard is squashed flat
* There are no jack brackets. however there is a jack jammed behind the exhaust pipes.
* There is no jack block
* The bottom "C" hook is missing, although the brackets are there.
* There is now a second US soldier on the back deck.
In terms of progress, I have completed the hull, and the rear plate is shown below. Jack bracket holes have been filled, as have the holes for the jack block. Bottom "C" hook has been removed, and scratchbuilt brackets added. Butterfly nuts have been added to both sets of "C" hook brackets.
Back to the workbench.
Regards
Rob
