Half a Year for a Half Track
Louisiana, United States
KitMaker: 459 posts
Armorama: 421 posts
Posted: Saturday, January 14, 2017 - 08:51 PM UTC
Got some paint down in the interior.
KitMaker: 362 posts
Armorama: 285 posts
Posted: Monday, January 16, 2017 - 12:41 AM UTC
image uploadHey guys ,WIP update everything falling together enjoying the build
photo uploader"Gonna start blastin"
...Stumpy
Rio Bravo 1959
#454
Georgia, United States
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Monday, January 16, 2017 - 04:42 AM UTC
Looking good, I'll be jumping into my build next week...
"I can make armored cars, safe and unassailable...and behind these our infantry will be able to follow quite unharmed and without any opposition."
-Leonardo da Vinci, 1487
Massachusetts, United States
KitMaker: 24 posts
Armorama: 16 posts
Posted: Tuesday, January 17, 2017 - 07:06 AM UTC
I'll be on mine in a week or two. These builds are looking great guys.
KitMaker: 3,353 posts
Armorama: 3,121 posts
Posted: Tuesday, January 17, 2017 - 01:35 PM UTC
Coming along nicely Guys.
I've cleaned up the road wheels and done the drive sprockets and started the turret. Not worth pics yet
On the Bench:
tatbaqui
News Writer
#040
Metro Manila, Philippines
KitMaker: 2,713 posts
Armorama: 2,451 posts
Posted: Wednesday, January 18, 2017 - 07:37 AM UTC
Tat, if you're after a set of the Tamiya decals for the Greif 250/3 I've got some you can have. I've just checked through my decals box and I've got some. I only used some number plate's and crosses off them as I did a straightforward half track when I built it 20 odd years ago so all the Greif and Adler markings are still there. The letters are red with a white border. Let me know if you want me to send them.
Sorry to have missed your post Karl. Does it also have "Greif" outlined in white only? Cheers, Tat
I picked up an ancient Gunze-Sangyo kit of Greif awhile ago and it also had red on both sides. I had to carefully cut the red part out of the outline, and of course the old decals disintegrated anyway. had to do a LOT of chipping to hide that mess, but in the end it turned out not half bad.
I remember responding to your old thread Mark saying there was one available that had the white outlined letters. That was the first thing I checked back after I bought the Dragon kit -- only to find out it was 1/24!
Namabiiru
Associate Editor
#399
Rhode Island, United States
KitMaker: 2,888 posts
Armorama: 1,920 posts
Posted: Saturday, January 21, 2017 - 05:06 PM UTC
#454
Posted: Saturday, January 21, 2017 - 08:40 PM UTC
That's a real bugger, Mark..from here all I can suggest is cutting the forks right above where the fender is and add a section of styrene there...if you can, post a front-on view...
Namabiiru
Associate Editor
#399
Posted: Saturday, January 21, 2017 - 09:59 PM UTC
I'll have to take that under advisement. Going to be tricky, but may be able to make it work.
I went back to look at my reference photos and noticed that the support arms linking the forks to the pivot are angled from the forks as opposed to being a right angle, as DML molded it, so they tend to be more parallel to the ground:
So I went and surgically deconstructed the entire thing to drop the fork a bit, and here's what I came up with:
Closer, but still way off. As requested, here's a front-end shot as it stands now:
I'm thinking maybe instead of cutting the forks above the fender, perhaps cutting them at attachment for the fender stabilizer where the fork is smallest. That will also allow me to replace the stabilizers that look too thick for scale.
#454
Posted: Sunday, January 22, 2017 - 12:56 AM UTC
I agree, seems there's little else you could do with it
KitMaker: 3,033 posts
Armorama: 2,492 posts
Posted: Sunday, January 22, 2017 - 01:16 AM UTC
Hey Mark,
I just had a look at the Kettenkrad I built several years ago and it has the very same issue. However, I weathered mine for a muddy environment dio base which I believe would have solved the problem, but that hasn't happened yet. If I get a chance, I might just see the doctor about doing a little nip-and-tuck. ... Or maybe I should just get motivated and make that base for it!
Good luck!🍺
—mike
KitMaker: 459 posts
Armorama: 421 posts
Posted: Sunday, January 22, 2017 - 02:33 AM UTC
Mark
Seems the only solution is to get out a really sharp razor saw and take your time. Think about making new pins for the suspension arms to attache them back to the body.
Namabiiru
Associate Editor
#399
Posted: Sunday, January 22, 2017 - 05:47 PM UTC
Mark
I do need to get some more detail on the scratched bits, true; however, after going over reference photos again and again I think I have the final solution. The main reason I didn't want to just drop the whole assembly down where it attaches to the body because it would have had the handle bars sitting too low, but Dragon has simplified the whole arrangement so much that the handlebars are lower than they are supposed to be anyway. So by dropping the whole assembly and mounting the handlebars on an extension on top I think I will have something fairly close. Looks like rubbish at the moment, but hopefully once everything is in place it will all come together.
Word to the wise: if you ever feel like building a Kettenkrad, stick with Tamiya.
Posted: Monday, January 23, 2017 - 01:53 AM UTC
Small M21 update. ... Mines! ☠️
—mike💥
KitMaker: 459 posts
Armorama: 421 posts
Posted: Monday, January 23, 2017 - 02:21 AM UTC
Mark
Mark
I meant to go at it from the other end, raise the wheels by cutting the arms and swinging them up the required amount.
Namabiiru
Associate Editor
#399
Posted: Monday, January 23, 2017 - 05:06 AM UTC
Mark
Mark
Oh, Okay. I follow you now. Had actually considered that idea, but had to discard it outright. The swing arms are so petit there wouldn't be enough mating surface to get a strong enough bond, but more importantly raising the road wheels enough would make the whole thing look like it was carrying an elephant unless I raised all the wheels, in which case there wouldn't bee enough room to fit the tracks.
Appreciate the inputs and suggestions!
Posted: Monday, January 23, 2017 - 06:15 AM UTC
Hi guys,
Here’s another installment on the M21.
I revised the instruction sheet's assembly sequence quite a bit ... leaving the track suspension off, several large panels, and the fighting compartment items unglued. The kit practically snap-fits together at this stage!
The driver ... no snap-fit here! It took quite a bit of effort to seat him into the cab properly — didn't look believable; he seemed a little tall in the saddle, even with the optional sunken seat cushion (K8). With a little fancy Ginsu blade action to the torso, butt, driver seat, he sits just fine now.
Cheers!🍺
—mike
#454
Posted: Monday, January 23, 2017 - 06:21 AM UTC
Looks like a perfect custom fit, Mike!
Posted: Tuesday, January 24, 2017 - 04:18 AM UTC
@ Irvin and Ken, Looks like you guys are in paint or close to it already.
@ Mark, Hope the Kettenkrad stops misbehaving like das 'Katzenjammer Kids!'
@ Clayton, Thanks!
I went back and had a look a the mines — realized I forgot the handles. Good lord those things are tiny! ... No wonder! 🔎
Cheers!🍺
—mike
Namabiiru
Associate Editor
#399
Posted: Tuesday, January 24, 2017 - 05:40 PM UTC
Thanks, Mike. I actually got the final assembly done last night and it's just about ready for primer. I think the heavily modified front end came out not-too-bad in the end, but if definitely killed my idea of a quick build.
Posted: Wednesday, January 25, 2017 - 02:30 AM UTC
Here’s another small M21 scratch modification.
Plan A: Lots of fun last night … almost 6 ft. of wire stripping was needed to make only two runs of cable! 😅
Plan B: Buildup the drum diameter with Tamiya 10mm Masking Tape. 😋
Plan C: Revisit my winding work and do a better, more uniform job? ... TBD. 🤔
Cable is a 0.24mm strand pulled from an unknown wire gauge. Chain is LZ Models (35602) Precision Medium Chain.
Not perfect …
… but better than the kit version???
Waiting for some nuts and bolts to arrive for the mortar base 🔩 ... no rivet counting though! 😄
Thanks for having a look!🍺
—mike
Namabiiru
Associate Editor
#399
Posted: Wednesday, January 25, 2017 - 04:01 AM UTC
Looks better to me, Mike!
#454
Posted: Wednesday, January 25, 2017 - 04:37 AM UTC
I concur, that winch is a gem.
KitMaker: 362 posts
Armorama: 285 posts
Posted: Wednesday, January 25, 2017 - 05:03 AM UTC
Hi Mike, I like what your doing with the M-21 it is much nicer than the Tamiya that I am working on. I would like to build a dragon however I am waiting for the right stuff for IDF version. I just saw a group of figures in the process of being Sculpted they look really sharp how long I need to wait who knows
...Stumpy
Rio Bravo 1959
Posted: Wednesday, January 25, 2017 - 06:13 AM UTC
Many thanks guys, I really appreciate the comments!
@ Ken, You prompted me to go on one of my Google search tangents (half-track, half track, halftrack) when I happened to come across this kit version — never knew of it until now:
Dragon (6359) IDF M3 Halftrack. Maybe you were already aware?
Curious … Which figure sculpts are you referring to?
Cheers!🍺
—mike
