Looking fine Mike. No never too many pics.
Nice fix on the K Rad Mark. That is what Dragon kits are all about - reminding us of the 'good old days' where scratch building and test and fit and adjust, test and fit and adjust, was our motto! Had to do this for the 250/9 as you will see.
Okay, tedious work on road wheels and track done and turret started.
Just a few tips for anyone attempting one of these in the future....
1) completely build the front axle assembly and do the 2 runs of tracks (or sufficient to rest the road wheels on)before adding any of the torsion arms for the rear wheels.
2) Build all road wheels and cement halves together before adding the torsion arms.
3) Test fix front wheels before adding torsion arms(blue tack is good as the fit is terrible and the wheels will fall off without it)
.. do you see where I am going with this?
4) clean up all torsion arms ready for assembly.
5) put the idler mount away some where safe. DO NOT FIT IT
5) Quickly fit all torsion bars, then fit the road wheels. Once done, immediately locate the road wheels on the two track runs and adjust torsion bar heights so all road wheels as sitting flat on the track and camber of the wheels are all in line. Support rear of vehicle will help. and leave for torsion arms to set.....
Failure to do the above, or fitting all torsion arms perfectly level with hull bottom will likely result in the front road wheels and track section being airborne when the front wheels are attached.
Do not glue the rear idler mount until you have test fit the completed track sections around the idler, Drive sprocket and road wheels AND ESPECIALLY do not mount it vertical as Dragon shows you in the instructions or your track section will be too short to fit..... and no, adding another track link will not fix it, as then the run is too long and you have gaps around the idler and/or sprocket.
TEST fit always!!!
Enough talk, some pics
