Tamiya, 3T Cgo Trk (Opel Blitz), 1/35Well, Hey Now...whataya know! My above posted test fire worked out, all in one shot!
Dinner's in the oven and I've got my cocktail in hand and feeling cocky now...I think I'll drive on with my "Love-Hate" relationship review of the resin aftermarket
Panzer Art Early Commercial Tires intended for the Opel Blitz.
I've seen this set on many retail sites and on
Panzer Art's home page more than once and always with a CAD photo of their product. I searched high and low and couldn't find a review or a pic of the actual product and finally decided to pull the trigger and ordered the set and crossed my fingers. When the wheels arrived, lightning fast, to my doorstep I was more than happy with my purchase.
Armed with my newly purchased magnified reading glasses
I quickly busted open the well defined box (also adorned in the CAD drawing) and proceeded to examine my purchase - $14 or $15ish, by the way. I was more than impressed! The resin detail is comparable with that of
Model Victoria. The tread detail is crisp and clear with only a small pore stub to deal with. The sidewalls are adorned with
Dunlop and size lettering and is absolutely phenomenal in clarity. The 6-hole opening wheels even have a finely molded air filler valve! I couldn't have been happier and I was on may way to backdating an early 1938-39
Opel Blitz for this campaign.
The pic below shows the
Tamiya front wheel on the left and the
Panzer Art front wheel on the right. In this view you can clearly see the fine detail and even the minute valve stem.
Well, while working on the earlier mentioned brakeline plumbing and while attempting to dryfit the wheels/brake drums to the frame's drivetrain, I soon discovered
Panzer Art's downfall.
Though they are exquisite in detail,
Panzer Art fell down in a big way in the engineering department! There is no way these engage with the
Tamiya kit or any other manufacturer's Opel Blitz Kit, I suspect. The reverse side of the hub or the mounting interior of the wheel, if you prefer, is nothing more than a solid stub not able to accept any kind pin from the front or rear axle. This set is going to require some thought, creativity and patience if you wish to "Make it Happen" as they say in the Army!
First off a 5/64 hole was carefully drilled into the center of the inside plug, making sure not to drill to far and punch through the exterior detail. Next a test fit of the kit brake drum inside the wheel assembly revealed a deep dish profile on the
Panzer Art wheel. Left unaltered I think the finished assembly when mounted to the front suspension would end up with to narrow of a profile when view from the front and sitting inside the fenders. This was when I was about to abandon
Panzer Art's early road wheels and just go with the kit's wheels, but that wouldn't go with the early interpretation of the Blitz I intended just for this campaign, so I thought and thought over some days and drove on...Hell, this is a lot for a decade break in service from this building. In the end I resorted to the tool hardware bins and found a metal flat washer which inserted inside the wheel assembly and then followed by the brakedrum brought the assembly to where I wanted it to be.
Clear as Mud, Right?
Well, maybe some pics might explain it better.
Below the modified wheel on the left and the original product on the right, waiting for drilling and application of flat washer.
Don't ask me what size washer this is because, honestly, I grabbed the first one from my bin of many and low and behold it fit snugly and perfectly on the first pass. This was one of those moments I had to step back with OMS (Open Mouth Syndrome} and just gaped in amazement, because it's never supposed to be that easy...not the first round at least! I know some of you know what I'm talking about.
In this pic, hopefully you can see the difference between the unmodified wheel and brakedrum on the right - and the flat washer modified wheel and brakedrum on the left. This modified assembly is more like the kit assembly and will hopefully allow for correct wheel spacing when assembled to the suspension. Another bonus is the flat washer is identical in diameter to the kit brakedrum and actually enhances the look when viewed from the openings of the wheel exterior!
The rear wheels brought on their own set of problems to solve, if the front set was not enough.
Panzer Artprovides five (5) identical rear wheels for assembly. One, which is supposed to be used as a spare requires you to drill out the molded lugs. I was really surprised at this, really, come on
Panzer Art! But, drill away you must to represent a proper spare for your kit. Again, all being identical pieces the deep dish when paired created an extreme gap between the two paired rear wheels, much like the Russian GAZ series of trucks. Again, some more thought and a couple beers and premium cigar
In the pic below you will see the two paired together unaltered with an extreme gap {l} they would probably become an issue with the fender when installed later.
My modified set (c) which resembles more closely the original
Tamiya assembly (r).
The deep dish on the interior wheel needs to be cut out and then glued to the exterior/wheel adding the separate hub to the assembly, which, by the way, also needs to be carefully drilled out to mate properly with the rear axle pin
When viewed from the outside of the assembly, if the six(6) lightening holes are aligned properly the interior cut is not visible and all looks correct.
Whew!!! Don't know if I'll do that again.
Finished wheels below
Love those air valves, tho!
Time for a
