KitMaker: 462 posts
Armorama: 417 posts
Posted: Monday, November 21, 2016 - 10:31 PM UTC
Sounds good Matthew! Are you sure the tracks alone will add more then 200-220 parts to the overall count?
I'll check tonight. I think they certainly will if you count each of the connecting bolts that hold the tracks together
If not, I'll build the MiniArt T44M.
Matthew
Oklahoma, United States
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Tuesday, November 22, 2016 - 05:17 AM UTC
I talked with John/Nito and everything is sorted out. I shall continue the M1070 build. Thank you John.
Bayern, Germany
KitMaker: 1,615 posts
Armorama: 1,500 posts
Posted: Tuesday, November 22, 2016 - 11:45 AM UTC
Thanks Matthew!
There is enough to build for two campaigns on that kit Dustin!
Glad you and John sorted this one out.
Building logs: http://armored76.wordpress.com/
Finished projects: http://armored76.wordpress.com/portfolio/
KitMaker: 462 posts
Armorama: 417 posts
Posted: Wednesday, November 23, 2016 - 04:08 AM UTC
Christian, in addition to the kit parts there are 180 tracks links and 360 resin pins to hold them together. Do the pins count?
Matthew
Bayern, Germany
Posted: Wednesday, November 23, 2016 - 11:25 AM UTC
Thanks for checking Matthew! The pins count if these are assembled on the model. Absolutely! Sounds like a lot of "fun"
KitMaker: 462 posts
Armorama: 417 posts
Posted: Wednesday, November 23, 2016 - 12:20 PM UTC
Oh yes, assembling those tracks is going to be a whole lot of fun!
Bayern, Germany
Posted: Saturday, November 26, 2016 - 07:28 PM UTC
Just scratched this up on the ol' photoshop. I'll probably have more ideas later on.. probably..
Thank you Bryan! I made this the official campaign ribbon.
Bayern, Germany
Posted: Tuesday, November 29, 2016 - 11:12 AM UTC
The games are officially open!
Have fun everyone!
Belgium
KitMaker: 25 posts
Armorama: 23 posts
Posted: Tuesday, November 29, 2016 - 08:31 PM UTC
here we go had a few hours to build today.
one off the 8 you have to make for the drive train.
Mark
Bayern, Germany
Posted: Tuesday, November 29, 2016 - 11:32 PM UTC
Vietnam
KitMaker: 416 posts
Armorama: 312 posts
Posted: Wednesday, November 30, 2016 - 07:16 PM UTC
Hi,
The second Smerch followed Mark's one, but it's from the Trumpeter.
K.
Bayern, Germany
Posted: Wednesday, November 30, 2016 - 07:18 PM UTC
Side-by-side builds! Great!
KitMaker: 32 posts
Armorama: 28 posts
Posted: Thursday, December 01, 2016 - 11:14 AM UTC
Decided to Dump the RFM Tiger Build. I started it a little early and Just couldn't get excited about, so I dug out all the parts for the AFV Nashorn I had sitting about for sometime
I will make the proper part count adjustments once I figure how much of the PE I will be using.
(220 Track links and 110 Ice Cleats plus the pins in the Kaizen Winterkettens) and I will be scratch building/kit bashing an engine and drivers compartment.
This is one of those builds I have been putting off for sometime so I think it will be a good one for this build.
Bayern, Germany
Posted: Thursday, December 01, 2016 - 11:29 AM UTC
Looks like a great kit... To be honest I never heard of it before but then again I'm no WWII specialist.
Please do let us know about the part count once you have it. Thanks!
Belgium
KitMaker: 25 posts
Armorama: 23 posts
Posted: Thursday, December 01, 2016 - 03:18 PM UTC
Bayern, Germany
Posted: Thursday, December 01, 2016 - 05:38 PM UTC
Looks nice! Is it glued together or just test fitted? Will you be able to paint the inner parts if everything is glued together?
Belgium
KitMaker: 25 posts
Armorama: 23 posts
Posted: Thursday, December 01, 2016 - 09:59 PM UTC
Everithing is glued but i think there Will be No problem for printing
I Will see when thé primer is on
KitMaker: 32 posts
Armorama: 28 posts
Posted: Friday, December 02, 2016 - 03:48 AM UTC
450 Parts in the Kit itself, 330 in the track Kit. and another 600 in PE. But I figure what the PE replaces in plastic and since I will be including some of the Interior, it should be around 900 give or take.
Minnesota, United States
KitMaker: 597 posts
Armorama: 439 posts
Posted: Friday, December 02, 2016 - 06:51 AM UTC
Cristian, I looked all night for parts counts and came up empty.
The two I have in mind are the Takom Chieftian Mk 5 and MENG T-72b3.
I have the Takom Chieftain Mk 10 and wanted to build it for this campaign. Here is my parts count (yes, I counted every part on each sprue...)
Sprue A - 74 pcs (x 2 sprue) - 148 pcs
Sprue C - 55 pcs
Sprue D - 54 pcs
Sprue E - 34 pcs (x6 sprue) - 204 pcs
Sprue F - 7 pcs
Sprue G - 9 pcs
Sprue J - 15 pcs
Sprue M - 22 pcs (clear)
Indy Tracks - 200 pcs
P/E Fret - 42 pcs
Upper Hull - 1 pc
Lower Hull - 1 pc
Turret Top - 1 pc
Turret Bottom -3 pcs (cupola rings)
Poly Cap - 2 pcs
Gun Mask - 1 pc
By my count (and I could be off) I show a parts count of 765 pieces (thank you indy track pads). So it should be allowable for the campaign.
If it is, I'm in. If not, I'll have to dig through one of my Dragon Premium kits that are over-engineered to high heaven!
Hard to believe that no matter what site I went to, NOBODY had a parts count on the Chieftain...
EWC(SW/AW) USN 1990-2005
IPMS #46275
Posted: Friday, December 02, 2016 - 07:59 AM UTC
Tat & Cristian - Thanks for the help fellas. I currently own both kits, but I've been out of town for work. I just got home and counted the Takom Chieftain Mk 5P. It comes in at 772 parts including indi link tracks, track pads and PE. If this is ok then that'll be my entry.
I counted my Mk. 5 and this was my comment on page two.
KitMaker: 597 posts
Armorama: 439 posts
Posted: Friday, December 02, 2016 - 08:29 AM UTC
Totally missed it on the second page!
IPMS #46275
Bayern, Germany
Posted: Friday, December 02, 2016 - 11:17 AM UTC
Thank you for the part counts Billie Jean, Matt and Dustin! All those kits are a great fit for this campaign.
Looking forward to seeing those parts glued and painted!
Maryland, United States
KitMaker: 1,183 posts
Armorama: 628 posts
Posted: Saturday, December 03, 2016 - 12:11 AM UTC
I finally talked myself into joining. This is the first one in a looooong time too so I figured I'd do it up right. I'm going with this big boy:
I started a few weeks before the official start date but I have lots of pieces to go before I'm done. This is what I've done so far:
And this is how many total parts to the kit:
I've originally got this kit years ago and eventually sold it. I just recently bought it again. Watching this thread and seeing that terry (messynachos) was in for building one, I figured I'd join up myself. I have no idea where I'll put it when I'm done, but I'll cross that bridge when I come to it.
So anyway, hopefully it's not too late to join up and if it's not, I'm happy to be here.
A well regulated militia, being necessary to the security of a free state, the right of the people to keep and bear arms, shall not be infringed.
#454
Georgia, United States
KitMaker: 1,273 posts
Armorama: 1,138 posts
Posted: Saturday, December 03, 2016 - 12:49 AM UTC
We were allowed to start early for this Campaign, so you should be cool. I'm building the Morser Karl Gerat, so maybe we should chip in together for a 5 gal. bucket of German Grey paint, LOL....
"I can make armored cars, safe and unassailable...and behind these our infantry will be able to follow quite unharmed and without any opposition."
-Leonardo da Vinci, 1487
Lisboa, Portugal
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Saturday, December 03, 2016 - 01:37 AM UTC
Here's the KitMaker Gallery for the finished builds:
HERE !!! And I will be in with a Miniart T-44 tank.
Active Builds: 0
Active Campaigns: 0
