Paul and Hans,
Thanks guys for checking in and typing a few nice words.
The two draggers are indeed ICM dudes to start with. If you go back in the thread here you can see the mods I did with them. I used Dragon helmets,weapons and gear though,with Hornet heads.
The hedge was made using small twigs for the bottom thicker parts and sea foam for the tiny twigs on top. The para canopy was cigarette rolling papers,cut into wedges and glued together. This was cut into a circle,water was added and it was draped over the bush to dry.
HTH guys,
Rock on !
J
Dioramas
Desperate Times at LeGleize.
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Sunday, February 12, 2017 - 12:31 AM UTC
ahandykindaguy
KitMaker: 1,295 posts
Armorama: 1,191 posts
Posted: Sunday, February 12, 2017 - 02:08 AM UTC
I would have to agree with you about that Jerry, I don't mind if someone says it, but I'm looking forward to the day I hear it in person from Him...
Have a great Sunday mister.
BUTA46
KitMaker: 117 posts
Armorama: 113 posts
Posted: Sunday, February 12, 2017 - 06:37 PM UTC
Them there Canadiens do have a way with their words!
A trick to try with the parachute is to put the cut up papers in place on a glass pane and use the diluted latex mixture on one side only. Let this dry. Then use a safety razor (no, not the back of number eleven) to scrape the whole thing off. The glass side will be smoother. This will look a lot like silk. When you want to position the 'chute, use a wet paint brush on the glass side to moisten it enough to put it into position. Let this dry. You can always re-wet this side to move it around until you like what you see.Then coat with a satin clear acrylic and paint if needed. I made a spiffy looking t shirt for my current project this way.
jrutman
Posted: Sunday, February 12, 2017 - 07:16 PM UTC
Interesting method for sure. The pics don't show it well but my chute is fairly translucent and even has tiny ribbing in it like an old canopy would. It was printed into the paper.
J
