Welcome Anthropoids to the weekly fix, seems there’s around 700 regulars on board now which amazes/humbles me - thanks for your interest & apologies if this seems to be dragging, but as I mentioned early in the blog if I can’t/don’t get this car looking as good as (or rather better than) my abilities allow there’s little point continuing with the rest of the project. It’s sure stretching me to the limit.
So to the last big scratch item - the tilt, my Apollo 13-air-scrubbers-improvisation moment: make this fit to that using only what’s on the table:
The MiniArt Ukranian building window frame & those end-thingies (Dragon or AFV Club T34 final-drive hull plates?) never expected this…
It seemed a good idea to make the whole tilt detachable to avoid conflicting priorities of gluing it in place vs. painting the boot/trunk lid underneath it. Wire retainers fed under the seat-back plus a locating bracket on top ensures the tilt assembly will sit at the right angle…hopefully it’ll also be less likely to disintegrate just before Final Dio photography…
…and then various Evergreen to fill out & further strengthen the overall form...
The cover’s made from my usual 3 ply tissue bathed in double-cream-consistency acrylic paint. A paper stencil finds the tricky points of fit/contact so that actual fitting shouldn’t hold any surprises…
Jury’s still out on the colour, the real thing appears to be somewhere between light black & dark grey but I’ve given it a brownish tinge for now…
The side brackets were vexing, nothing in the spares boxes remotely usable so they had to be scratched from spares shrapnel. That same day I came home with a Molotow pen, tested it on a panel prepped for paint trials…
…and then on the brackets themselves…
It's easy to use & can be decanted for use with a fine brush for fragile parts. It does seem prone to wear if you look at it too long, I need to try it over a proper primer & under a protective varnish probably – it don’t like masking tape over it bare. Nevertheless thanks again Brian/Russ, you made my day.
I see it’s not exactly sitting in place or at the right angle (should be raised higher at the back) but it’s only resting on its bracket for photos. Also the lamp’s so close/harsh it’s washing out the dips & contours too much, looks better in natural light.
I’ll need to see the whole tilt against the black of the car before deciding the final shade, it can be tweaked with light acrylic washes and/or dustings of pastel powder…that was the other reason for making it detachable.
After my scratch-fatigue’s worn off it’ll be high time to finish interior fittings, then off to the paint-shop.
