Time for small update. But first some explanation.
I like when I cover all variants of some vehicle with kits from same producer. They look alike. Since Tamiya Horch 108 1a is too old and have too many mistakes, I decided to try to convert Icm Type 40 to 1a standard. Still not shore how it will turn out at the and but for now I am happy, especially by not cutting my self.
So...
I started by cutting rear wheel arches
and fixing rear gasoline filling spot. I used cut off peace as an insert.
After that I cut off peace of body from one side of semicircle and glued it to another side, effectively moving wheel arch location.
Than I removed part of body between two doors.
I made break drums and easy on/off resin wheels attachment.
I cut front doors before placing them with idea to fix interior details lost by cutting
but that was a mistake because curve did not match so I had to use doors from another Icm kit. Same happened with the floor after realization that Tamiya spare wheel section does not fit inside space between two doors. After some research I find out that Type 40 had 20 cm shorter wheelbase then 1a. So I had to insert piece of placard in the middle of the floor... Perfect fit.
Then I removed part of cargo compartment cover, added some wood planks and removed reducer
Fixed front of the body...
... engine bay and front bumper...
chassis and drive components...
And here I am now.
This is what I am aiming for
So front hood goes to the spare parts box.
Sorry for long update, maybe someone sometimes is going to make same conversion so this can be useful.
I still have a lot of job, will keep updating.
