As mentioned I already did some building, before joining the campaign. Pictures show what I have to build again for the Dragon 88mm. after this one is finished.
The bronco kit starts with building the 'Lafette cross". a logical first step. But I could not resist building the Sd.Ah. 202 first. Beautiful molded by Dragon, for people unknown, same set goes for the Dragon and Bronco kit. Very nice and a joy to build.
I made the front piece steerable, preparing for diorama settings. Except for the Pioneer tools it's complete and primed with 1200 grid out of the can, also the tires are primed, this time with 1500 black, both primers are from Mr. Hobby. Needs to get a rubbing with a Scotch & Brite pad, to get rid of some spots and rough grinding and after that it will be stalled for the paint job later on.
Next step is building the Lafette cross to support the more complexed building of the gun itself.
Some pictures:
Neutral position.
Turned to the right
Turned to the left
With wheels temporarily added
Steering is made possible by drilling the links and adding micro tube instead, so I can put bolts in. Will use some resin or RB Motion pieces, still to decide.
Question comes up how to connect both sides when the Sd.Ah. 202 is moved unloaded.
Does anyone know if the connection bar to connect both sections is included. Can not find it right now. Do other manufacturers add that detail?
Love the build so far, see what challenges the gun will bring.
Hope you all enjoy,
Until next time,
Robert Jan
