Instructions
Parts
You are provided two type of tow cable "eyes". The difference is their length, as you can see in the picture.
I selected J86 as it looks like the one used in pictures from my reference books.
RFM uses 3 separate pe parts for the headlight. I found this to be a real pain in the a** to assemble to the headlight. So, I left it off.
The fit of the fenders is not a problem.
The fit of the roof to the superstructure is not perfect. It doesn't sit squarely without a little persuasion.
Pics of finished build
As you can see, the superstructure DOESN’T fit on the lower hull. This is very disappointing. I may play around with the fit and see if I can improve it, but I’m not sure I have the skill level for that.
The level of detail in this kit is next level. With that comes many frustrating issues with getting it all to fit properly. Clearly, I wasn’t successful in getting it perfect. I’m sure more experienced builders won’t have the same issues as I came across. Many times, I had to walk away from the table for a few days and come back with a clear head.
Overall, I enjoyed the challenge of the build, and I was able to push my skill level up a notch. For those that will be building this in the future, hopefully I have highlighted one or two things to help you.
On to the next build.
