- Projectile compartment opening, wiring tubes, control box all replaced.
- Access holes in the front section added
- Angled plate below access holes added
- Spot welds added (inside and outside)
- Gunner access door relocated centrally under the gun hatch ring mount
The proportions on the kit are quite distorted and even what I have done is not 100% correct, but the best I can do to align things as much as possible to the turret dimensions.
Scratch built tools and fittings missing from the kit, added hooks for the canvas cover sometimes fitted, clamps and straps, as well as the tie downs for further straps to be added later. Also replaced moulded on blob handles.
The etch on the panel in front of the MG hatch ring is in the kit, it is for the strut that supports the MG when not in use.... but the strut is not provided. Mainly due to the completely wrong and out of proportion mount for the MG they provide - the strut would not fit!
What HB Gives you a tube projection for a pin under the gun. Also note the additions already added to the hatch - HB give you just a single moulded on handle (Also note the original parts placement of the access door and projective opening before my mods)
The offending DsHk M mount replaced by a scratch built one, with the gun now further forward, the recuperators(?) now correctly angled upward and closer to the gun, not horizontal and spaced out wide, plus RB barrel added. Still need to add the rear sights and the under gun box which needs to be made ... HB's is too big, too low, wrong shape and had no back! (and also would foul the before mentioned strut.)
And the major rebuild of the gum mounts under way... HB gives you the thin bits on the mount and a big empty space...
Lastly, the work in the front of the gun mount area. I have only done what is visible with the gun in its transport cradle. Anyone wanting to do the gun raised would have a more massive rebuild to undertake, as HB give you very little here and what they do give, is not even close to accurate.
I have also added the strut mechanism in the turret wall and replaced the point on the wall top front that HB give you with the correct bevelled profile
