Shermans!
endrju007
Wojewodztwo Podkarpackie, Poland
KitMaker: 2,435 posts
Armorama: 1,256 posts
Posted: Sunday, April 13, 2008 - 04:40 AM UTC
Hi,
Marcin, here is the ribbon in gif format, under 1kB:
I have to confess that I didn't even start yet... I'm still working with Blitzkrieg entry and I'm also quite busy in some other ways at home... I hope I'll be able to start the work this month!
Andrzej
beefy66
KitMaker: 971 posts
Armorama: 280 posts
Posted: Sunday, April 13, 2008 - 08:09 AM UTC
Any one out there know what is the best kit to do the Crab Flail have the legends convertion set and I,am wanting to do a british M4A4 version or was other types used
INDIA11A
KitMaker: 577 posts
Armorama: 446 posts
Posted: Sunday, April 13, 2008 - 09:06 AM UTC
Keith, use any of the Dragon M4A4s, Any one with the 75MM gun (sorry don't have the kit #s handy). Just remember this A4s need the lower hull shortened as they are too long.
I have a Coree flail that I am waiting (building courage) to build.
You could also use the VC variants and close of the loaders hatch and sub a 75MM for the 17 pdr. As above some of these kits need the lower hull shortened.
Hope this helps.
Stefan- I don't think the M4 High Speed Tractor was built on the Sherman chassis.
Doug
INDIA11A
KitMaker: 577 posts
Armorama: 446 posts
Posted: Sunday, April 13, 2008 - 09:12 AM UTC
Martin- You should be able to use a M4 interior in a A3. As long as its a early- mid production and not a 47 degree hull (wet storage). The drivetrain (for an A3) from the engine to the transmission will be lower than in a M4. The instrument panel for the driver would be different but the rest should be basically the same layout.
Doug
WARLORD
HISTORICUS FORMA
Warszawa, Poland
KitMaker: 1,923 posts
Armorama: 868 posts
Posted: Sunday, April 13, 2008 - 08:05 PM UTC
Hi,
Andrzej
Thanks Andrzej, I'll upload the ribbon in few minutes.
I've started my Sherman. So far it goes OK but I still have track assembly ahead
A model for Blitzkrieg will be built just after Sherman is finished.
surgeon01
Berlin, Germany
KitMaker: 204 posts
Armorama: 98 posts
Posted: Monday, April 14, 2008 - 04:01 AM UTC
Hi there,
a campaign for shermans .... what a great idea! Please count me in. At the moment I'm not sure on which one I will start.
Thanks
robert
surgeon01
Berlin, Germany
KitMaker: 204 posts
Armorama: 98 posts
Posted: Monday, April 14, 2008 - 05:17 AM UTC
Hello again,
so I will enter with a M4 A1 in quarter scale. I'm thinking of two options: one from Operation Husky in Sicily 1943 or Operation Cobra Normandy 1944, both of them would be in a two-colour camouflage scheme.
greetings robert
tread_geek
KitMaker: 2,847 posts
Armorama: 2,667 posts
Posted: Monday, April 14, 2008 - 10:22 AM UTC
I am making somewhat slow but steady progress on my Sherman. The HVSS units are now complete and the return rollers are in place.
Here is a somewhat better view of the beasts parts.
Currently I am gluing the suspension units to the hull as well as the front differential cover and the rear hull section with exhaust deflector, tow hook assembly and clevis loops/rings
Good luck to everyone!.
Jan
Martinnnn
Zuid-Holland, Netherlands
KitMaker: 5,435 posts
Armorama: 2,762 posts
Posted: Monday, April 14, 2008 - 10:40 PM UTC
Hi all,
Thanks for the replies regarding the M4A3 interior.
I first started on my M32. Pics will follow but suspension, some lower hull detail and first steps in a simple, mostly scratch-build interior have been taken
Already love this campaign. Shermans rule
edit: the first pics of my M32...as you can see I still have quite a lot to do
Maurice
Friesland, Netherlands
KitMaker: 254 posts
Armorama: 75 posts
Posted: Tuesday, April 15, 2008 - 10:24 PM UTC
Hi,
Also made a start with the 1/72 M10 Achilles IIC, working on the suspension now. It is a nice model, though there is some flash at the moldlines here and there, but the parts fit well.
One problem I did come across is the absolute lack of color reference on the instructions, all there is to go by are 3 tiny photos on the box.
I'll try to post some images of the progress so far this weekend.
Bye,
Maurice
AECUPP
KitMaker: 4 posts
Armorama: 3 posts
Posted: Tuesday, April 15, 2008 - 11:31 PM UTC
SOUNDS GOOD I'LL DO THE M7
SGTJKJ
#041
Kobenhavn, Denmark
KitMaker: 10,069 posts
Armorama: 4,677 posts
Posted: Thursday, April 17, 2008 - 07:23 PM UTC
My Sherman is moving along. All construction is finished, mud applied to the running gear, and a white base coat is on. Next is the camouflage - I have not decided whether to go for an overall olive green camouflage or a olive drab with hard edged sand camouflage. A quick and nice build
Final pictures of the end result will be of better quality
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Friday, April 18, 2008 - 08:22 PM UTC
Progress is swift the base coat is now on and next is the decals before the weathering starts.
More to follow...
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Saturday, April 19, 2008 - 05:24 AM UTC
Work has progressed through the day today. The Italeri/ESCI Sherman M4A1 is a fine little kit with no major problems so far.
The only critique would be that the modeller is forced to construct the ID number from small individual numbers. This is extremely difficult to line up. Furthermore it is difficult to correctly space the numbers as the decal film has to overlap between the numbers. There should be the solution to make the number by one self from many pieces or use a finished one piece decal with a generic number. Then the modeller would have a choice.
Next is the final weathering so I will probably finish this one in short time. More to follow
Tomek_K
Wojewodztwo Dolnoslaskie, Poland
KitMaker: 150 posts
Armorama: 131 posts
Posted: Sunday, April 20, 2008 - 06:41 AM UTC
Hi all
I've started build log of my Polish Firefly VC:
http://armorama.com/forums/117721
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Sunday, April 20, 2008 - 07:59 AM UTC
Here is my finished Sherman M4A1 for this campaign. It is the 1/72 Italeri/ESCI kit. A nice kit especially considering its age.
I have already bought my second entry for this campaign, the Tamiya 1/35 Sherman 105mm. I am now planning some kind of diorama...
AlanL
KitMaker: 14,499 posts
Armorama: 11,675 posts
Posted: Sunday, April 20, 2008 - 08:12 AM UTC
hi Guys,
OK count me in. Do partly finished kits count or must I build from the start now? I have 4 to finish from last year!!!
Alternatively I could do A Sherman IIA from 2RTR in Italy 1944. September, I should be able to make that lol, lol.
Al
endrju007
Posted: Sunday, April 20, 2008 - 07:29 PM UTC
Jesper,
very nice model as I remember it is 1/72... must be a tiny
I haven't even started yet... I'm still involved in Blitzkrieg...
Andrzej
WARLORD
HISTORICUS FORMA
Warszawa, Poland
Armorama: 868 posts
Posted: Sunday, April 20, 2008 - 08:01 PM UTC
hi Guys,
Al
Hi Al
What is the status of your builds?
If it's more than 25% yould start should start new build and if not you can enter with already started model.
tread_geek
Posted: Monday, April 21, 2008 - 02:37 AM UTC
I'm impressed with the speed and results posted here. My 1/72 Dragon Sherman is coming along but I am having to relearn a few things after all the years away from the hobby. I now believe that I picked quite an intimidating kit. The kits that I built in the past were lucky to have 60 parts but this one has almost triple that.
The lower hull and suspension are pretty much complete as the following pictures will show. I am experimenting with various weathering techniques and am not totally sure of what I am doing.
Side view of the Sherman with initial weathering steps.
Looking at the bow.
With the upper hull just placed on the chassis.
Have also had to relearn how to use an airbrush. Hope this built turns out okay!
AlanL
Posted: Monday, April 21, 2008 - 07:24 AM UTC
Hi Marcin,
Thanks, looks like it will have to be a new build, the others are well on their way to completion.
Al
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Monday, April 21, 2008 - 06:21 PM UTC
Jesper,
Andrzej
Thanks, Andrzej. Yes, definitely a small model. It is not going to fill the shelves
szpxxx
Budapest, Hungary
KitMaker: 32 posts
Armorama: 25 posts
Posted: Tuesday, April 22, 2008 - 04:22 AM UTC
Hello All,
I'm trying to post a photo here, but -durin the uploading process- I always receive the following message as a result:
Warning: fopen(/home/kitmaker/gallery/uploads/28732/index.htm): failed to open stream: No such file or directory in /home/kitmaker/gallery/pp-inc.php on line 3034 Warning: fclose(): supplied argument is not a valid stream resource in /home/kitmaker/gallery/pp-inc.php on line 3035
What does it mean? My fault?
Thanks,
Peter
INDIA11A
KitMaker: 577 posts
Armorama: 446 posts
Posted: Tuesday, April 22, 2008 - 03:49 PM UTC
WIP of my M4A1. Hodge podge of parts, TTW upper hull ( Had to add 3/32" to rear), Tamiya turret, Dragon lower etc. Thank god for a big spares box.
Bit more done after these pics taken; mantlet/ gun added to turret & details added to rear of lower hull.
Next suspension. Hmmmmm which box to look in for suspension??
Doug
muttley
KitMaker: 251 posts
Armorama: 202 posts
Posted: Wednesday, April 23, 2008 - 06:06 AM UTC
Awsome job done on the 1/72 M4A1 there Jesper
I remember these small kits way back, heck I even used to play with them like a toy with the old Matchbox 1/76 toy soldiers
