The Workhorse: Panzer IV
Emeritus
Uusimaa, Finland
KitMaker: 2,845 posts
Armorama: 808 posts
Posted: Sunday, October 10, 2010 - 03:03 AM UTC
Though it initially looked a bit daunting, fitting the RB Model wasn't that hard after all.
After measuring the length that needed to be removed from the kit barrel, I marked it with a felt tip marker and carefully cut and sawed off the required amount, finishing off with a file to get the cut as straight-angled as possible. To get the hole for the barrel's locator pin both centered and properly alignment, I started with a much smaller drill bit and used several gradually larger ones until I reached the required 2mm size.
And it worked! Dryfitting showed a nice snug fit to the kit barrel (or what's left of it) as well as the mantlet.
eqNeal
KitMaker: 39 posts
Armorama: 36 posts
Posted: Sunday, October 10, 2010 - 04:50 PM UTC
I managed to get a bit of work done this weekend.
All assembled, track links are glued together but roadwheels and sprockets are removable to help in painting.
all primed and ready for basecoat:
jaberwaki
Georgia, United States
KitMaker: 109 posts
Armorama: 97 posts
Posted: Sunday, October 10, 2010 - 06:05 PM UTC
i had better get off my dead butt and get busy. i have chosen to build tristar panzer IV B. this is my first tristar build and am looking forward to it. i just hope mine measures up. some of you guy have amazing talent.
Tojo72
KitMaker: 4,691 posts
Armorama: 3,509 posts
Posted: Monday, October 11, 2010 - 04:45 AM UTC
Nice work Neal,looks good.
Jedge3
Michigan, United States
KitMaker: 258 posts
Armorama: 208 posts
Posted: Monday, October 11, 2010 - 04:20 PM UTC
So here are a few work in progress pictures. I haven't assembled a model in over 10 years and well let's just say I need to learn to glue again....forgot how CA glue can be.
Also, I decided to use some photo etched parts for the first time on this model just to see how it would go. Well, since these old kits needed a lot of help, I was not prepared for all the updating. Some went well some not so well as you can see by my use of the kit parts in some areas. I had some MIA parts that either fell someone and I can't find them or that during the updating with the PE, I lost the spacing needed as seen with the missing jack on the right side. I put the track link out to far but I don't want to try to remove them, it took me a while to get the PE brackets right.
Overall it has been fun and I hope to have it all together soon to prime, paint and weather. Which will include some new firsts as well. I plan to make the DAK version. I was hoping to find the Bison decal set for the DAK and the Panzer IV but it appears to be no longer in print and eBay was a bust.
Anyone that has built this one before, it is the Tamiya Panzer IV D, does the upper and lower hull just sort of sit together in the rear? I keep thinking it needs to be a better fit but not sure. And is that large gap underneath normal, kind of like the space on the Sherman?
Already have my next model ready to go for the Shoot back campaign!
Thanks,
Jeff
eqNeal
KitMaker: 39 posts
Armorama: 36 posts
Posted: Monday, October 11, 2010 - 04:53 PM UTC
The Barrel store is listing Bison PzKpfw. IV in Ausf. D set as in stock so you might want to give them a ring. From looking at the decal picture I see some DAK markings, not sure if that was the set you were looking for or not.
item # BiD35027
http://www.thebarrelstore.com/Markings.htm
I do remember something funny about the fit between the upper and lower hull, it might have been the inner rear fenders as I left that part off of mine when I built it. Hopefully someone else here has a better memory
Jedge3
KitMaker: 258 posts
Armorama: 208 posts
Posted: Tuesday, October 12, 2010 - 03:39 AM UTC
item # BiD35027
Thank you I will check them out and see. And yes it is the inner rear fenders that seem to fit funny with the back part of the lower hull and I don't want to go cutting away at them if that is supposed to be how they fit together.
SGTJKJ
#041
Kobenhavn, Denmark
KitMaker: 10,069 posts
Armorama: 4,677 posts
Posted: Tuesday, October 12, 2010 - 11:18 PM UTC
Looks good, Neal. I like that you have personalised the Pz. IV with track links and tow rope etc. Gives it a more "lived in" and realistic look.
Looking forward to see it in colour
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Tuesday, October 12, 2010 - 11:43 PM UTC
Thanks. I guess I'll have an overlaping build.
Getting kind of a late start, but I am expecting my 35 Academy Tiger I mid pro. w/interior to arrive soon. I should have plenty of time to finish, by the deadline.
Matt,
The Tiger campaign starts December 5 here is the link for that tread
https://armorama.kitmaker.net/forums/165272&page=1
Braille
#135
KitMaker: 1,501 posts
Armorama: 1,485 posts
Posted: Sunday, October 17, 2010 - 08:23 PM UTC
Eetu,
Though I'm thinking of building it mostly OOB, I'm not making any promises. Those OOB promises seem to be those I can't keep...
Well, mostly OOB if you don't count the zimmerit it'll need. That'll be my first. Now asking about the best zimmerit-making methods is like asking what's the ideal dunkelgelb paint mixture, but here we go. I was thinking of regular milliput, with the pattern imprinted with a suitable tool. That OK?
I personally don't have any experiance with applying Zimmerit coating to a model but I have seen several modelers use Mori Mori Putty. If your still in the market for a Zimmerit putty to use here is a link to Sam Dwyer's DML Panzer IV Ausf. H Build Log where he uses that putty on his build with some really good close up photos.
The Mori Mori putty is available at Hobbylink Japan.
-Eddy
eqNeal
KitMaker: 39 posts
Armorama: 36 posts
Posted: Tuesday, October 19, 2010 - 01:03 PM UTC
After a few rainy days a update, I'm mostly done except for some minor detail painting and flat coat. Should I go for a more beat up look with more chipping?
Tojo72
Posted: Tuesday, October 19, 2010 - 02:08 PM UTC
looks good Neal,I would vote for at least a little more weathering and grime,not too much,just a little.
Ruffus
Guatemala
KitMaker: 343 posts
Armorama: 223 posts
Posted: Tuesday, October 19, 2010 - 02:09 PM UTC
It looks nice, but a little more weather can make it "shine"; that, an the flat coat you talk about.
Byron
ltb073
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Tuesday, October 19, 2010 - 02:28 PM UTC
[quote]After a few rainy days a update, I'm mostly done except for some minor detail painting and flat coat. Should I go for a more beat up look with more chipping?
I would say to add a wash to dust it up a bit more but other than that it looks great, don't care for that crazying chipping look
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Wednesday, October 20, 2010 - 09:41 PM UTC
Looks good, Neal. A little more weathering - especially on the suspension. No more chipping is needed in my opinion. It can easily be overdone.
Otherwise it looks nice.
rtvmodeler
#136
Distrito Federal, Mexico
KitMaker: 437 posts
Armorama: 391 posts
Posted: Thursday, October 21, 2010 - 07:10 PM UTC
Nice works friends!. Well, now my health is good and I re-start my work.
I drilled the plates for adding screws, well, I have a little failures in the align - I hope to solve it with a good weathering and/or add-ons.
Ready more PE for the rear plate and front mudguards - The exhaust Pipe is of resin.
Assembling the Compartment Engine of resin of TWS, it arrived damaged, but not problem. I am reviewing the space before to glue and detail. About the Engine, I added in scratch the tube, hook and styrene.
I painted with red-hull of Tamiya all the interior plates. The next step is to painting with blank of Tamiya except the engine compartment.
Soon more pics!
Rodolfo
eqNeal
KitMaker: 39 posts
Armorama: 36 posts
Posted: Friday, October 22, 2010 - 12:24 PM UTC
I added another grimy wash and lightly dusted with some pigments. I'm going to consider the build finished at this point. I had alot of fun building this and it was the first time using photo etch and pigments.
Ruffus
Guatemala
KitMaker: 343 posts
Armorama: 223 posts
Posted: Saturday, October 23, 2010 - 05:59 AM UTC
Rodolfo, seems to me like it's a lot of work ahead of you, looking good though; and I know it may be too early, but what scheme are you planning to use?
Saludos
Byron
retiredyank
Posted: Tuesday, October 26, 2010 - 09:29 PM UTC
What is the deadline for this campaign??
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Tuesday, October 26, 2010 - 09:37 PM UTC
Great project, Rodolfo. It will be interesting to follow.
Very nice finish, Neal. Thanks for sharing
Ruffus
Guatemala
KitMaker: 343 posts
Armorama: 223 posts
Posted: Thursday, October 28, 2010 - 06:14 AM UTC
december 31 2010. remember to enlist.
Byron
rtvmodeler
#136
KitMaker: 437 posts
Armorama: 391 posts
Posted: Friday, October 29, 2010 - 09:11 AM UTC
Thanks for your kind comments friends!.
Saludos
Byron
I am thinking in the scheme used in Kursk for the third Regiment Panzer, vehicle 633.
Rodolfo
rtvmodeler
#136
KitMaker: 437 posts
Armorama: 391 posts
Posted: Friday, October 29, 2010 - 09:17 AM UTC
Hello friends!
Here more pics:
I painted with white of Tamiya all the interior plates. I am working with more details inside of the chassis (floor in grey, some cables, radio, washes, etc.).
Rodolfo
Ruffus
Guatemala
KitMaker: 343 posts
Armorama: 223 posts
Posted: Friday, October 29, 2010 - 12:04 PM UTC
Looking good!! it's coming along nicely. keep it up compadre!!. viendo las fotos, se nota en el 632 una especie de caja, interesante.
Happy modeling
Byron
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Saturday, October 30, 2010 - 09:15 PM UTC
The interior looks great, Rodolfo. It will be a pity to cover it up.
Very nice choice of camouflage scheme.
Looking forward to see more
