No offense taken and I am not going to say for a minute that I have the wheel geometry perfectly correct but . . .
In a turn, the outside wheels scribe a wider circle than the wheels on the inside of the turn and therefore do not angle as sharply.
Also, in a turn, the wheels on the second axle turn a bit more, relative to those on axle #1.
I may have over or underdone (or both) this affect but the above logic is what I was trying for. I was sweating bullets trying to get this to come out correctly.
Posted: Thursday, September 01, 2016 - 06:08 PM UTC
Posted: Thursday, September 01, 2016 - 06:28 PM UTC
CR@P - I'm WRONG!
I just rechecked my references and my second point is WRONG! Never trust your memory!
The wheels of the front axle angle MORE than those on axle #2 not the other way around!
The first point is correct however.
Now what am I going to do? - Gonna have to think about this one! - Back to the alignment rack!
This page is one-half of a WWII German engineering document covering the geometry of 8 Rad steering.
Posted: Thursday, September 01, 2016 - 07:27 PM UTC
Since I am not having the wheels roll perhaps I can shave the wheel axles a little to reduce this condition.
Posted: Thursday, September 01, 2016 - 07:58 PM UTC
Posted: Thursday, September 01, 2016 - 08:21 PM UTC
Posted: Thursday, September 01, 2016 - 09:54 PM UTC
Posted: Friday, September 02, 2016 - 11:02 PM UTC
Perhaps rather than install a complete radio just install the mounting base and speaker? I think I might be able to come up with a scratch built radio base at least.
As someone said early on; at first they had to check them out everyday and even dismount the aerials so a rack without a radio would not look out of place.
(Photos from the Prime Portal website; Taken by Don Busack - Shown here for discussion purposes only.)
Posted: Saturday, September 03, 2016 - 10:54 PM UTC
Posted: Saturday, September 03, 2016 - 11:15 PM UTC
Posted: Sunday, September 04, 2016 - 08:39 PM UTC
Posted: Sunday, September 04, 2016 - 11:17 PM UTC
Taylornic
Tennessee, United States
KitMaker: 337 posts
Armorama: 332 posts
KitMaker: 337 posts
Armorama: 332 posts
Posted: Monday, September 05, 2016 - 03:39 AM UTC
Keep up the great work!
Posted: Monday, September 05, 2016 - 04:44 AM UTC
Now I have GOT to consider this as serious progress!
Early on I built the first cylinder only to immediately discover the problem with the internal ejector pins. I am afraid I have been shying away from taking on the rest of these hydraulic cylinders but now, finally they are complete.
I also replaced the cast on hydraulic piping with .015" plastic rod.
Posted: Monday, September 05, 2016 - 04:59 AM UTC
Interestingly, in this Italeri kit, the main hinges of the LHS and the larger hydraulic cylinders are fairly well retained but for some reason the pivots of the two smaller cylinders are not retained at all???
But of course they are on the real thing!
As you can imagine the ones on my model are now ALSO retained!
(Original un-cropped photos of LHS equipment are from the Prime Portal website as taken by Dieter Krause - Used here for discussion purposes ONLY)
Posted: Monday, September 05, 2016 - 06:01 AM UTC
Posted: Monday, September 05, 2016 - 08:33 AM UTC
Minor F.Y.I. On shipping info:
For rail shipping or any other need where vertical height must be reduced; removing the upper stay bolt on the hook arm will allow you to rotate the arm back and downward.
If I had known this prior to assembly of the model I would have drilled out this top stay bolt and replaced it with a piece of plastic rod to allow me another way to pose the model.
Only found one photo showing this break down and now I cannot find it again so I altered the above drawing.
______________________________________________________________________________________________
Below is shown the shipping dimensional plate from the driver's side inside door. Note LHS hook in stowed position.
________________________________________________________________________________________________
Navy/Marine Mk?? 16.5 ton LHS I am currently working on:
Posted: Monday, September 05, 2016 - 11:12 PM UTC
I have been planning on just what I might do with the open engine cowl. I knew I could not simply use the stock cut-away hood piece as it is much too thick. I spent a good portion of
last night forming and shaping a thin piece of
plastic sheet. This morning I braced it in a
way I thought made sense and here it is.
Epi
KitMaker: 3,586 posts
Armorama: 2,556 posts
Posted: Tuesday, September 06, 2016 - 02:02 AM UTC
Great work on the engine cowl Mike.
I was going to cast you a radio this weekend, but the family made last minute plans to go to Canyon Lake for some camping this weekend to get me out of the apartment. Well worth me going because Sunday night before heading to bed, I got a 10 lbs carp. Largest fish I've caught in my life.
Posted: Tuesday, September 06, 2016 - 05:39 AM UTC
Thanks Pete - fishing is always a more than excellent reason to not do whatever might otherwise be on your plate. Don't worry too much about the radio.
I appreciate anything you might do for me but the radio is a ways down on my list along with the winch and the gun ring. Gotta learn more about what is available to the model market and what is correct for the HEMTT with the SINCGARS. Right now I am still thinking of including only the empty power supply/amplifier baseplate and one of MikeyBug's speakers plus an empty antenna mount.
DocEvan
KitMaker: 180 posts
Armorama: 180 posts
KitMaker: 180 posts
Armorama: 180 posts
Posted: Tuesday, September 06, 2016 - 06:58 AM UTC
Mike, all I can think after seeing your work here is "I'm not worthy! I'm not worthy!!"
You are building THE definitive HEMMTT!!
[quote]I have been planning on just what I might do with the open engine cowl. I knew I could not simply use the stock cut-away hood piece as it is much too thick. I spent a good portion of
Posted: Tuesday, September 06, 2016 - 09:55 AM UTC
Doc - Thank You for your kind words. I certainly hope you are right. I hope the Dayton judges this weekend agree with you! (That is if I finish by Saturday morning.)
Posted: Tuesday, September 06, 2016 - 10:26 AM UTC
Engine installed, radiator still giving me problems, the air tanks have had piping installed. Tomorrow I must get those brake cylinders installed - they are too good looking and too visible to pass up!
(The #6 air tank is optional to only the semi-tractor. Otherwise all required air tanks are represented in the Italeri model.)
Posted: Tuesday, September 06, 2016 - 07:38 PM UTC
Thank you to everyone for all the support, information, encouragement, compliments and even spare parts that have been shared during this project!
Mike
Mike
Posted: Tuesday, September 06, 2016 - 09:38 PM UTC
Posted: Tuesday, September 06, 2016 - 09:51 PM UTC
