hey Jan, that's a great suggestion, thanks for this, but stays the question: how do you actually hold the stuff?
both the Dremel and the bit of wood you have to "turn", I guess you have you have to buy some sort of support. i see
Dremel sells one, but it looks quite flimsy.
hey Scott thanks for this, yes it slowly begins to take shape, the really difficult part of this diorama will come
soon enough: I mean, the big turret..
yes Alex, i wonder how I managed to do all those yeras without a Dremel kind of tool. Do you roll your cigarettes
Alex? I used to do, and it's exactly the same thing to roll those guns and here turret: p^roceed with very light
fingers. Actually I grease slightly a sheet of glass and roll the stuff gently until it's more or less the right
shape. then when it's thoroughly dry, I sand it until it's okay.
Thanks Jon, it looks alright like that, but I did one of my major mistakes at this time: this form is exactly the
same size as shown in the plans, which means that when i will vacuform the turret it will be oversized because of the
thickness of the plastic! I had to sand it quite a lot after those pics..
Now one important part of this build is the railings that you can find on each side of the whaleback -you also have some shorter ones on the cabin: on this picture you can see both the elements I used (brass sheet and small circles of photoetched brass left from a previous session) and some detailing job done on the hull itself.
So first some holes in the plastic
Then inserting some small brass sheets in the hole and try to solder the 2 at each end -i used the Dremel to get a smooth effect just like it was on the real boat.
this view show the final result complete with the material I use: as small Weller iron, some Carrs flux and solder.
notice the railings on the cabin are done as well. No sweat really. the thing is to try to pin one drop of flux on each joint, so that it sort of absorbs the heat from the iron -this way you don't burn the plastic underside!
