hey Martyn thanks, yep it all begins to take shape..
Claude, this was 1mm thick plasticard, i needed a bit of thickness so that i could cut properly and sand the cones of the air intakes. Of course once done, I realized that the thickness was indeed varying throughout all the inner surface but well..
A big flat NO for the hairdryer, you need something stronger, but then i found a first price for paint remover/heater at 10€ in a Brico-Dépo.
Jon, take a lot of care with the kind of styrene you use. And especially the transparent one! I will go back to this when I start the turret but I threw away some 5 sheets of transparent styrene in order to make the thing (
Well, if it's just to make some light bulb, a simple candle should be enough
I will Libor thanks
Well Soeren, I certainly learned the hard way with vacuform, simple shapes like my air intakes you succeed in a matter of minutes, but more complex shapes .. well.. it reminded me of my first tries with homemade photoetch!
Anyway here's the box I use, all the stuff is covered with some plastic sticking paper for packets as I needed the whole to be really "airproof" the whole surface is covered with holes actually, but as I only needed a small surface for the vacuforming, I covered most of the surface as well.
Yep, MS for doing groundwork, i know a fig sculptor over there at HF that uses it, but I tend to think that those material are not very good for this as you get too much control with MS, while basically you should not control that much
I'd be curious to see your tries for a desert diorama though!
Ein fröhlig Neu Jahr zu dir!
So first here are my air intakes completed, with some brass tubing and MS to make the joint
so eh.. let's try to do the same for the turret!
hmm.. well, no, not that good. As you can see the turret is pretty high and the plastic has got some trouble to "'fold" neatly around that shape
So, why not trying to make 2 halves and then afterwards trying to bind them?
looks better..
a bit of saw job..
