hey Jan, you bet I have something in mind with the water
You know I just can't start a diorama if i don't have anything particular and new in mind, and here it will be the water definitely.
Now about the compoistion -please consider those 2 dioramas that were done at 15 years of interval
and
On the first case you can see a typical balance -that I personally call "the sun balance" as everything seems to sort of revolve around a same centre point.
I did a lot of dioramas according to this scheme, up to a point that at one moment i thought i couldn't escape it.
But then more recently i tried with different sorts of composition. if you look at the other one, there is absolutely no balance of the elements, yet it works because of the way the stuff is orientated. because of the colours etc.
With Spaceman 3 I will hope to sort of create a momentum and a colour scheme that will create some sort of balance despite all the "raised" elements being to the right -when you consider the diorama from this side of course..
Because this balance/ composition element must also work FROM EITHER SIDE OR ANGLE YOU ARE CONSIDERING YOUR DIORAMA.
I know you are an adept of the "stairs" diorama, which can typically be considered best only on 3 of the 4 sides of a square -the front being always preferred, while I prefer "unclosed "dioramas.
i consider this
one as being a success of Sun Balance because from whatever angle you look at it, the composition works perfectly.
So all this to say that composition and balance on a diorama doesn't work the same way as it does for a painting, that achieving something good can be both difficult and risky ..
Thanks Scott -yep something special is going to happen, but like usually comes right at the end, the stuff must click together you see, and sometimes it never does.. It took me 9 months to make galilée click for instance.
Thanks Al my friend, that really appreciated! You know what they say, Humour is the politeness of despair. Sadly I am neither Jew nor British so my possibilities in humour are rather restricted, yet I do my best!
Oh dear Jon, I knew that the prices of housing in London got mad, but going as far as Minsk! This is ridiculous! yet at least when you visit your friends in London you will be able to say you saw REAL snow!
Thanks Martyn, this time i am back here for good!
Just those 3 pics today
That all very well this plaster thing, but thereal job was to TRIM it!
I have been using my Dremel to do this in places...
some plasticine form around the plaster..what for duh..
