Thanks for your nice words guys!
Paul yes, in the need that will be more "hard weathering" than battle damage, but there's sure one place where i took the best of the accident -nice story! But that's precisely the reason why there is this metal circling around the turret -so that they don't shoot their own masts and turrets et al.
thanks Nico!
thanks Scott, you know that's just this diorama should have been finished the first week of January, and that it lingers because of this never ending winter and accidents like this one (not the first one, I had a light bulb crashing on the boat too !)
Well, in the end a slight demotivation creeps in, but I'm harder than this.
Thanks Jon. No I didn't see those sailors you write about, I will check, but i'm either too stupid or too proud to even consider buying a fig ever again
Thanks Bob, realistic battle damage uh?
The problem is that there is 3 mm thickness of mastic at that precise spot, a bit thick for the real thing!
Well Guy, I won't say I feel happy that i'm not the only one to which such a thing happened, but i certainly feel supported
(still waiting for new stuff from you btw)
Andrzej what a string of weird things happening to you!
first: the framing is being made of *wood* NOT platsic. use Plasticine for kids to cover every joint
I still have some stuff running but less like so till I was really cautious with that. As for paint, use oils, the transparent ones available in art shops are a must.. will wait for your new tries then!
So I basically had some extra sanding to do, tamiya mastic applying, sanding again?. What worries me is the photoetch frame of the windows which suffered quite a lot and will stay somewhat bent no matter how hard I try.
Here I am doing the windscreen again. it's transparent evergreen + a CA glue coated framing.
