Hi guys, here are the pictures of my work.
Here are some images that I was inspired to correct and to complete my model. The schema has enabled me to calibrate the volumes and dimensions of the various parts, as can be seen from the pictures of the view of the model together with all details assembled but not fixed.
The schemas of detail allowed me to identify all the parts to build / modify and their exact location. Of course, was necessary to reach some compromises (as little as possible).
Other total views to appreciate all the details so far realized.
First of all, I have completed the fire alarm system by placing all the cylindres of Argon gas, is that the pipes. To complete this system, I will have to do even the control box and his protective mask that will be placed on the hull near the pilot's place (and to do this I still have a little time). I had already made a master of a cylinder of Argon gas which I then duplicated in resin, so I can use them also for my Rescue Leopard.
I also repositioned in the correct position the two tanks compensation for oil of the hydraulic controls of the pilot (the two small tanks to the left of the gas cylinders).
I have completed the heating system by adding the commands for the opening / closing of the pipe unions of the air intakes system inside the hull , the seals of the expulsion chamber of the exhaust gas and the relative command to its closing in case of immersion tube and the pipes and cables for the supply of gasoil for the heating system.
I apologize for the bad photos. I'll make a new the set of images before painting and glueing all the details.
I have completed the right bulkhead with the electric cables for feeding of the command and control of the engine and of the various devices available to the pilot, with the pipes of the fire alarm system and the tubes of braking system and of the steering of the drive wheels.
As I mentioned earlier, I had to disassemble, rebuild and complete the flame arrestor bulkhead, thanks to some new pictures at my disposal. In particular, I have added all the details present, how the various wires and tubes, the controls of the drain valve of the engine compartment and the selector of the fuel tanks, the solenoid device for the "grounding" of the tank, the box of the small electrical heater for the food of crew, the "blades" filter and the feed pump for diesel heater ... and other controls and cables.
After that, I have completed the bulkhead on the left, starting to build the drain pump with its pipeline, the manual pump of the system immersion for inflating the pneumatic seals of the tower in case of diving, and one of the solenoid for the "putting ground "of the electrical system of the tank.
I also made the control levers for the air intake of the ventilation system to catch the air from the combat compartment in the event of immersion, which I fastened to the hull as well as in reality (vds also the image 08). I also realized the cylindrical container that contains the flexible corrugated pipe for heating inside the compartment of combat (vds. also the image 07).
I then completed the bulkhead on the left with the command of the brakes and the exhaust pipe of the water collected from the filter system anti-NBC (which I will complete it later with hoses, pumps and boxes of filters).
Here is an overview of the bulkhead on the left almost complete.
I have built the support for part of the control unit of the stabilization system of the turret and the pump for the expulsion of the powder of the filtering system anti-NBC.
An overview of the details as soon as made. The longer tube will be connected then to the main filter system anti-NBC.
The schemas of the interior of the hull and of the various details, are essential in order to identify the positions and sizes of all the major parts. Here is the complete set of views of the model with the upper part of the hull.
The front part of the hull yet without the driver's seat, a particular very complex to reproduce well.
The bulkhead right side, on which you can see the various parts fixed both to the hull, both at its upper part.
The flame arrestor bulkhead on the rear with all the wiring. Some cables will be put in place only after the final fixing of the bulkhead.
The bulkhead on the left illustrated as the right. The front part of the hull has not yet been completed and will be the next job. Then it's up to the turret...
Another little problem has been the realization of the holes on the hull for the ejection system of the exhaust gases of the heater. As you can see, there are some "corrections" of them (in fact, I had remembered that they were three holes, but not as they were willing) so I wrong them and then I had to correct the error after I finally found the image which reproduces their correct position. But, as we say, "Only those who don't anything, don't do mistakes" ... and I very wrong (fortunately there are the putty, the glue and the plasticard ...
For now I'm done and now I dedicate to make the details of the front of the hull, such as the filtering system of the compartment anti-NBC with their details and the rack of the ammunition (finally I got the pipes of proper size!) and the pilot's seat.
Until next time ... and any comments and / or suggestions will be greatly appreciated.
Best regards - Gianfranco
