Hello,
First time ever to build a Churchill. I chose braille scale thinking that less parts = less complications thus have an easy quick build.
Comes the mistake:
I thought the upper plate was a bad fit and that it should have lain flushed on the turret structure. Surely enough the references I have later checked indicated that I should have left it alone!
There goes my quick, one-session build. I sat there musing what to do next. After a day, I decided to try a fix:
I've re-scribed the outline with a #11 blade, and sanded down the outer edges to "raise" the plate. Seems to have worked.
I then moved on to build the hull tub and road wheels. This part also got me stumped for a while. For those building the Dragon #7510 kit -- the instructions have it wrong. For the drive sprockets it should be A24 + A27, and A25 + A28. For the parts that had the external road wheeels molded (B1 and B2) -- the installation should be the other way around not as what is stated in the instructions.
Next to tackle were the DS tracks -- never worked on DS before so I decided to google it up and see how it gets installed. Happy to have read that it does not need any special adhesive, but one just has to be careful not to use too much.
Instead of first gluing the ends and installing it, I found it easier to lay it on in stages and just wrap it around:
And yes, the Tamiya Thin Cement holds it quite nicely!
More to come.
Tat
