OK, let's try this again (friggin' Photobucket and Shockwave
Olivier - nice looking LAV-III. Other builds are coming along nicely as well!
@ John - I'll be painting this one overall green; other choices would have been UN white or tan.
@ Alex - the Real Model conversion isn't too bad - worth it for the p.e. alone. As you'll see it's missing a few small details though.
Continuing on:
Added the rear hatch extension with sheet styrene and lots of sanding. Anti-skid texture is made by stippling on lacquer thinner until appropriate texture is achieved:
Rear data connection hatch scribed in using template (copied from LAV-III hatch):
Armour mounting bosses cut from .030" rod cut with razor blade saw in mitre box:
Rear upper hull details complete:
Rear end complete. I had spent considerable time scratching the guard around the service air outlets when I realized there was a p.e. one I could have used!:
Muffler spaced out from hull with tube and brass strip support:
...and guard added:
The engine deck isn't quite right (rear grill isn't 'high' enough among other things) but I'm going to let it go on this one:
Now to add the rest of the hull p.e. and mounting bosses!
Jim
