I finally have a chance to post a little progress on my two entries.
Il-76:
This being my first Trumpeter aircraft kit, I have to say that I'm highly disappointed. The fit is
absolutely abysmal! There are huge gaps in fuselage sections, and the way some of the areas are engineered is questionable. For example, the "shoulder" into which the wings are mounted should have been designed as a single piece that drops into place, rather than just part of the fuselage halves. The resulting seam is going to be a chore to get rid of because the fuselage tops don't align very well. There is a ton of nice panel engraving that's going to need to get rescribed as a result. It's been probably a decade since I've worked on such a poorly fitting kit.
All that aside, I have a little bit of progress made, but all the filling and sanding is really going to lengthen time frame for this build.
Nose weights added to the insides of the fuselage halves. With all the cockpit and navigator window glazing and the lack of any interior parts provided, I decided to spray the insides flat black to cut down on the amount of light bouncing around inside.
A couple shots showing the gobs of filler I'm needing on the fuselage. The engines and wings are only slightly better fitting:
Panzer 38(t):
I'm having much better luck with the Panzer 38(t).
So far, I have the tracks together and some other odds & ends. I've done a little more work since I took these shots, and will try and post an update this weekend.
So far, the 38(t) has been a wonderful kit and the exact opposite of my experience with the Il-76.
