Wow....nice progress everyone! Thanks to the naval subjects, I couldn't resist the siren song and ordered my first ship model (and loads of other stuff) from the Squadron Black Friday sale: the Revell of Germany 1/144 Typ VIIC U-Boat, along with an Eduard PE set for it.
@MSCorley: Love the mantle on your ASU-85. I had been planning to try the old school tissue and glue technique when I get around to doing mine...great to see it's alive and well and looking great on your build!
My IL-76 is still stalled in the sanding stage. The poor fit and gobs of putty I've had to use and resulting sanding marathon have kind of soured it for for me, so I haven't felt like putting much tie into it.
The Panzer 38(t) on the other hand is coming along nicely albeit, with a little bit of frustration.
I thought it would be cool to try out my newly arrived AK interactive rust color set and spray a multi-hued rust coat to serve as the case to spray the AK Worn Effects fluid over, then do my Panzer gray modulation, stencils, then start chipping away. It all worked out....sort of.
All went well until I started the chipping process. In the past, I've used the AK Worn Effects over Tamiya paints, not using an intermediate clear coat. I've always been happy with the results. Not so much using it over AK paints. The paint came off in huge chunks, not the subtle, random chipping I was looking for. Not only that, but the rust coat was coming off too, exposing the primer. After pretty much trashing the turret, I stopped. The hull came out acceptable, but the turret had to be totally repainted, and stencils reapplied. Rather than strip it, I just sanded down the edges of the exposed paint with 1500 grit sandpaper. There are some edge traces of the original coat showing under the new paint, but I can use that to my advantage to represent damage or the like that was repainted by the maintenance crew.
I eventually got the turret repainted with stencils done.
As for the stencils, for my first real time using them, I'm happy. The numbers came out damned near perfect. The black in the Balkenkreuzen is a bit off center, but oh well. I'm not going to loose sleep over it.
During my after-action investigation, I remembered coming across a video tutorial on using the Worn Effects fluid a while back. In the video, the presenter tested different brands of paint with the fluid, including Tamiya and Vallejo. Tamiya gave the best results, as the surface apparently dries with slightly rougher surface than the Vallejo, diving the fluid something to grip to so it didn't come off in huge chunks. Methinks that was the issue: It's my understanding that Vallejo and AK paints are a very similar formula, hence the results I got. So, I'll try it again on the wheels but put a coat of Tamiya XF-86 Flat Clear on first, then the Worn Effects...and see what happens.
In the meantime, the hull and turret are painted and have a few applications of a couple MIG and AK filters applied.
Last night I did the sponge chipping and sprayed a satin coat to prep for washes and weathering. Maybe I'll be able to get some iupdate pics posted tomorrow.
