Haven't updated in a bit....since I put down the base paint on the truck cab and fenders.
I had gone back and forth on what I was going to do with the bed. I ended up just going with a flatbed. I had an old Bedford truck bed in the spares and the front from an old Heller deuce and half. I dressed up the side edges of the bed and added the bed rear, again from the old Heller kit.
I added the fuel tank.
I added the bulkhead of the bed. I messed up and I had to add a piece of styrene to the driver's side edge. I tried to get fancy and it didn't work so I had to fix it. I found a storage box for the other side. I think it was part of the old Bedford kit as well.
Added tie-down clasps to the bed and added bracing to the bulkhead.
Bed done, off to paint. More of my pale yellow. In real life the color is a pale yellow, similar to a color often seen on Studebaker vehicles. In the pictures, it looks more yellow.
After the paint properly dries, I'll add a company name to the doors. I figure this is a former Army truck pressed in to post-war construction company. I'll add a bit of wear and such and then I think it should be about done. I might add some construction supplies; pipe, lumber, bas of cement, etc.
