I had a pretty productive weekend.
The first thing was to photocopy the parts layout. Being of ICM origins, the parts are not numbered on parts trees. Overall, the parts are pretty good and the build looks to be pretty straightforward. There's a bit of flash. The parts that worry me the most are the individual track links.
I'm not going to go step-by-step on the build. Most of the build is pretty standard.
Lets start on the lower hull. Yay for one-piece hulls. Suspension bump stops.
Drive sprocket mounts and suspension arms added. Arms are keyed and fit pretty snug and straight & square.
Not shown, but I went ahead and prepainted the lower hull sidewalls and the roadwheels. The rubber parts were painted a lightened flat black and the contact metal surfaces got a dab of steel. Added a wash to the hull details. The black and steel should be toned down a bit in finishing.
Roadwheels, drive sprockets, and idlers added.
Hull rear plate. I left the jack off for painting.
The grilling on the engine deck are not backed so I added pieces of scrap styrene. I'll paint the squared one red-oxide and the round ones black or maybe dark-dark gray.
Underside view showing the rear deck inserts. The periscopes were added to the front. The instructions call for you to paint the front panzer interior buff, but you won't see anything after the hatch and hatch plate are added. Plus I plan to add crew.
Front glacis with driver's view port added. The MGer's letter box flap is molded on to the front.
And that gets us to the tracks. The tracks are delicate, especially the connection points. I have broken a few removing them and cleaning them up. I've noticed a few mismolded ones as well.
I'll probably slow down a bit and work on the tracks a few at a time. I'm ahead of schedule, so I can afford to take my time a bit.
