Armor/AFV: Modern Armor
Modern armor in general.
3D printed kits SPM. Modern/futuristic armor.
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Friday, July 10, 2015 - 07:42 PM UTC
A few more variants of m249 MK 48. Also MICO pack in 1/35 scale.
http://www.shapeways.com/product/GQCBDG423/1-35-spm-35-032-m249-mk48mod0-7-62mm-machine-gun?li=shop-results&optionId=57279199
http://www.shapeways.com/product/AZ6DBBWSK/1-35-spm-35-035-mico-machine-gunners-assault-pack?li=shop-results&optionId=57336104
spm_m249mk48_scL_6
spm_m249mk48_scL_7
spm_m249mk48_scL_8
MICO_pack_sp_1
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Thursday, July 16, 2015 - 03:12 PM UTC
The Lockheed Martin Gyrocam sensor system (15- Inch Triple Sensor 15TS/VOSS) added on Shapeways:
http://www.shapeways.com/product/ZZD6V9EWB/1-35-spm-35-039-lockheed-martin-gyrocam?li=shop-results&optionId=57386699
LM_GyroCam_2
LM_GyroCam_1
LM_GyroCam_3
rogerjo1
Västra Götaland, Sweden
KitMaker: 950 posts
Armorama: 905 posts
Posted: Thursday, July 16, 2015 - 03:26 PM UTC
Wow Peter, really nice
henkp
Overijssel, Netherlands
KitMaker: 1,080 posts
Armorama: 1,064 posts
Posted: Thursday, July 16, 2015 - 04:38 PM UTC
yesyes looks great thanks
amoz02t
#192
Kentucky, United States
KitMaker: 1,383 posts
Armorama: 1,281 posts
Posted: Thursday, July 16, 2015 - 08:02 PM UTC
Got my order in! Thank you Peter!
knewton
New Zealand
KitMaker: 1,217 posts
Armorama: 1,092 posts
Posted: Friday, July 17, 2015 - 01:31 AM UTC
Oh. My. Gosh. For the love of resin, that is beautiful. Now give me a figure to go with it all, please!
Off to order that "Ironman" pack.
thank you,
K.
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Friday, July 17, 2015 - 04:10 PM UTC
Thank you friends for your kind words!
The issue with the figure I hope to decide in August. I have to coordinate the technological issues with Shapeways. Backpack "Ironman" is essentially a test step for the production of figures by 3D printing method.
35th-scale
Kildare, Ireland
KitMaker: 3,212 posts
Armorama: 2,807 posts
Posted: Friday, July 31, 2015 - 05:39 PM UTC
I do like the look of all those bits! Wonder would that pack fit on one of the LR figures?
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Friday, July 31, 2015 - 11:27 PM UTC
Sean, I think the backpack can be used with any modern figures which similar for "machine gun on the edge"
The Marine Corps Transparent Armored Turret System (MSTAG turret)
Will be available at Shapeways in 1/35 scale on the next week.
mstag_tur_1
mstag_tur_2
mstag_tur_3
rogerjo1
KitMaker: 950 posts
Armorama: 905 posts
Posted: Saturday, August 01, 2015 - 03:10 AM UTC
Looking good Peter, seems like it will be a big order when i come home after my trip to Berlin
amoz02t
#192
Posted: Saturday, August 01, 2015 - 04:00 AM UTC
Hello Peter. The new turret looks great! I am in the process of putting the other SAG II turret together and have a question for you. For the transparent bullet proof ballistic glass, how do you suggest that be prepared? I am trying to sand and polish the minor printing steps out, and then coat with Future, but it still looks clouded so far. I am thinking it would be better to switch to styrene sheet for the glass? still looking for the proper thickness. Please looking for comments on what others have tried for the transparent parts? Thanks and wishing you much success. -S
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Thursday, August 06, 2015 - 05:25 PM UTC
The MCATS turret is available on the Shapeways:
http://www.shapeways.com/product/7MZTL3M2L/1-35-spm-35-040-mcats-turret?li=shop-results&optionId=57531146
http://www.shapeways.com/product/FUQVXHMNS/1-35-spm-35-040-a-mcats-turret-x2-in-set?li=shop-results&optionId=57531266
Stuart, I did some research on the replacement of windows in sets and have such ideas.
To replace armored windows details can use transparent plastic boxes from the CD/DVD discs. Standard box for TDK CD/DVD has a thickness of 1,3mm. Thin box TDK discs has a thickness of 1 mm. This plastic can be used for cuting of windows for SAGII turret. From the outside the glass to make a chamfer on the edges. To use 3D printed windows from set as template.
The using of plastic bottles for water capacity of 5 liters. The wall thickness on the side of the cylindrical part is 0.3 millimeters. Color plastic - colorless, blue, light green. This is similar to the shades of armored glass . I cut with a scalpel several strips 4X1,5 cm from smooth lateral part of the bottle. The strip is bent slightly as it is part of a cylindrical surface. It is not essential, because in the gluing process of the small squares (cuted from strip by templates) the detail is rectified. But it is possible to straighten the initial strip. This is done by thermal effect - smoothing-iron. Heat mode 1 or 2 (wool). Needs a wooden board (suitable board for kitchen cutting), the average thickness of cotton cloth (a pillowcase). Plastic strips to put on the board, cover with a cloth in two layers, press the heated iron on the one second, remove the iron for a few seconds and press again. You can turn up the strip other side on top and repeat the procedure. It may take several attempts for the experience.
From these strips can be compiled window glasses with different thicknesses. And one can use 1-2 liter plastic bottles, with thinner plastic (for the outside thin glass on MCATS turret).
Also, there is a packing boxes with transparent inserts (for the toy cars, dolls) and other packaging boxes.
I do not forget about the TOW sight, I try to do soon.
Roger, have a good trip!
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Thursday, August 06, 2015 - 06:01 PM UTC
The weapons look great. One question though, how many do you get in each set, Shapways doesn't say? I am specifically interested in the M240D (actually an M240H with the rail system added).
amoz02t
#192
Posted: Thursday, August 06, 2015 - 08:41 PM UTC
The using of plastic bottles for water It may take several attempts for the experience.
Thank you Peter! Good ideas and I will try some cutting. Looking forward to seeing more of your artwork. All the best to you!
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Tuesday, September 01, 2015 - 04:42 PM UTC
Gino, the Shapeways provides a report of all ordered sets. Info on prices and materials http://www.shapeways.com/materials/frosted-detail-plastic
My bonus is different for different sets. If you are interested in more accurate data, please send me a message
And I continues to joint project with Ant-Miniatures and we represent our next release:
ANT-35-705 m240L 7.62mm machine gun with adjustable butt stock.
ANT-35-706 Gun scopes: AN/PAS 13Cv3 Thermal scope, Trijicon ACOG 6x48 Scope, Elcan Specter optical sight, Meyers Glare Mout Visible Green Laser, DBAL-A2 Advanced Target Pointer/Illuminator Aiming Laser.
ANT-35-708 Assault trooper with m240L machine gun and MICO Pack ammo can.
ANT-35-709 cal.30 ammoboxes and cal.30 cartridges linked.
ANT-35-710 m249 MK48mod0 7,62mm machine gun, with LBT MK48 Box Mag.
ANT-35-711 LBT MK48 Box Mag.
SPM_ANT_p1_2
SPM_ANT_p1_1
SPM_ANT_p1_3
SPM_ANT_p1_4
SPM_ANT_p1_5
SPM_ANT_p1_6
SPM_ANT_p1_7
SPM_ANT_p1_8
SPM_ANT_p1_9
SPM_ANT_p1_11
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Thursday, September 03, 2015 - 12:06 AM UTC
All the kits are casted in resin and will be available on the next week on www.ant-shop.com
And the few pictures of gunner figure more.
spm_MicoGunner_1
spm_MicoGunner_2
spm_MicoGunner_3
spm_MicoGunner_4
spm_MicoGunner_5
spm_MicoGunner_6
spm_MicoGunner_7
spm_MicoGunner_8
spm_MicoGunner_9
spm_MicoGunner_10
spm_MicoGunner_11
meyrich
Arizona, United States
KitMaker: 12 posts
Armorama: 8 posts
Posted: Thursday, September 03, 2015 - 04:53 AM UTC
Hello Peter,
I just received my order of your 1/35th M249 MK48mod0 from Shapeways and I have a question. There seems to be a thin layer of gel like Vaseline all over the guns. The details on the gun seem very rough like slightly melted plastic. I'm hoping it's from the gel distorting the detail.
I haven't read anyone mentioning this gel before in this thread and was wondering if you, or anyone, had a suggestion on how best to clean it off. I've tried water and a brush and cotton swabs and they seem to just move the gel around.
Thanks for your time.
samofptr
Moscow, Russia
KitMaker: 130 posts
Armorama: 130 posts
Posted: Thursday, September 03, 2015 - 06:43 PM UTC
Matthew, thanks for your order! Here a link to the cleaning of printed models. Hopefully this will be helpful.
http://interurbanmodels.blogspot.ru/2015/04/how-to-clean-shapeways-frosted-ultra.html
Maybe try to use turpentine (solvent for oil paints). But first, test it on a separate portion of the surface. Also, a few tips for cleaning up:
http://armorama.com/forums/237594
https://aeroscale.kitmaker.net/forums/234938&page=2
And pay attention to the print quality. If there are print defects, the roughness of surface, the offset of printing layers, the model needs to be replaced by Shapeways.
And the completed renders of the Mico Pack Gunner. By the way, it's all handmade 3D modeling and sculpting, I do not need to use 3D scanners
[/url]spm_MicoGunner_12
spm_MicoGunner_13
spm_MicoGunner_14
spm_MicoGunner_15
spm_MicoGunner_16
spm_MicoGunner_17
spm_MicoGunner_18
spm_MicoGunner_19
spm_MicoGunner_20
meyrich
KitMaker: 12 posts
Armorama: 8 posts
Posted: Sunday, September 06, 2015 - 11:03 PM UTC
Peter,
Thank you for the quick reply and links. They are a great help. I appreciate it!
Removed by original poster on 09/08/15 - 13:35:15 (GMT).
pascalbausset
Moselle, France
KitMaker: 1,416 posts
Armorama: 1,379 posts
Posted: Monday, September 07, 2015 - 06:41 PM UTC
Hi all
Here is my story wth Shapeway product. I have bought a MCTAGS turret.
I receive a very bad model; I send them a complaint and they send me a second tuuret. A liitle better but far for the promissed product /
I send them a second complain and read what the answer :
"We're not reprinting this model.
It is described on our website and is unavoidable with this material that some parts of a model are being affected by the Support Material that's being printed with FUD.
Because of his design we aren't able to orientate the model in such a way that everything looks smooth and nice, actually this is impossible with most models."
So for 50€ i receive an unusable"sh...t". Thanks Shapeway
Maki
Staff MemberSenior Editor
Croatia Hrvatska
KitMaker: 5,579 posts
Armorama: 2,988 posts
Posted: Monday, September 07, 2015 - 07:10 PM UTC
I don't beleive the rough surface of this turret has anything to do with the orientation of a model for printing... It looks more like a bad print, possibly from using a bad batch of printing material?
Mario
BobSolo
KitMaker: 331 posts
Armorama: 112 posts
Posted: Monday, September 07, 2015 - 08:23 PM UTC
Surely if Shapeway cant print it they should have said.. "Sorry weve tried to print this and it doesnt work, heres your FIFTY EUROS back" ... not just send you the failed trial result and keep your money. Did you agree to PAY for their R&D with a chance of getting a good product afterwards? If not id ask for a refund and send them back the product if they wanted it back.
Cheers Bob
norbertJ
Loire, France
KitMaker: 219 posts
Armorama: 166 posts
Posted: Monday, September 07, 2015 - 08:44 PM UTC
could it be envisageable to make such prints on Reedoak Envisiontec printer ? We also have support material, but we place it manualy and you have a kind of "sprues" placed on spots that save details.
Norbert
ropeynz
KitMaker: 134 posts
Armorama: 102 posts
Posted: Tuesday, September 08, 2015 - 01:19 AM UTC
Pascal, have you had 3D models before? Is it a case of expecting too much from the medium? I have to say the photo doesn't look so bad to my eyes but I have had NO previous experience so may be talking b@ll@cks.
