Brent, thanks for the comment, the opinion of professional is most valuable! Thank you for your photo collection by ITAS on the http://www.hmmwvinscale.com/apps/photos/album?albumid=11839569 ! I took out a lot of useful information![]()
I can make a model of the LBB battery and charger, this elements of the TOW system. These parts are arranged in the luggage compartment of Humvee and not visible from the outside. What are the views of modelers, such details are necessary or not?
Stuart, I'm glad you liked the model, is now the scene “Humvee TOW in Mosul, Iraq July 22, 2003” will look like complete![]()
The battery/charger is an important detail as they are still connectrd to the TOW sysytem when it is vehicle mounted.
What would be ideal is if you did the LBB and included the mounting bracket for the interior. The internal mounting is different in the M1121 as compared to the M1167.
The new sets added on Shapeways.
TOW Weapon System upgrade kits:
- Lithium-ion Battery Box (LBB) with Vehicle Mounted Charger (VMC), + x2 in set;
- TOW upgrade full kit - Improved Target Acquisition Subsustem (ITAS) with Position Attitude Determination Subsystem (PADS), TOW Fire Control System (FCS), Lithium-ion Battery Box (LBB), Vehicle Mounted Charger (VMC).
http://www.shapeways.com/product/CY9LM5Q6N/1-35-spm-35-027-tow-04-tow-upgrade-full-kit?li=shop-results&optionId=58320998
Heckler & Koch 45 Compact Tactical Pistol, in 1/18, 1/16, 1/6 scales, and keychain
http://www.shapeways.com/product/B8WCHFWSX/1-6-spm-6-001-hk45-02-h-k-45c-suppressor-version?li=search-results-1&optionId=58235751spm_hk45_sc_2
spm_hk45_sc_1
spm_TOW_ITAS_2
Ian, to commc boxes, probably I do such details a little later. According to the tank crews, I have taken note of, but I can not promise it![]()
Brent, the LBB mounting bracket for the interior looks on schemes as a simple frame (if I understand correctly), I think the easiest way is to cut such a piece from a plastic.
Peter,
I will photograph them before and after the primer and upload the results. The parts have very few visible printing lines on them. I can't see how they will require much in the way of prep before the primer. Now I have to buy the new battery and charger! If I had known they were coming I would have waited and bought the set! These are going in an M1045 I'm working on from the 101AD in a build log.
