Looking good!
69mudbone-Half track is looking good. Anxious to see the next stage. The pictures show the preshading to good effect. Be aware that oils are usually applied over a gloss not a flat coat. That said there are those who do use oils over a flat. The advantage of gloss is that it makes it easier to remove the oils. They can still be removed from a flat but it is a bit more difficult, especially to remove them completely. Good luck!
Quoted Text69mudbone-Half track is looking good. Anxious to see the next stage. The pictures show the preshading to good effect. Be aware that oils are usually applied over a gloss not a flat coat. That said there are those who do use oils over a flat. The advantage of gloss is that it makes it easier to remove the oils. They can still be removed from a flat but it is a bit more difficult, especially to remove them completely. Good luck!
Flat is good if you are doing a filter, but washes do tend to work better on a gloss finish.
Thanks Guys, I have read it finished in two different ways I will try this and make notes, I have a BM-13 rocket launcher built that I will try different methods I really enjoy experimenting to find what feels good
Hi Guys, WIP update. Put the 20 year old decals on they held up fairly well , and initial weathering , waiting for flat to dry and will give oil colors a shot . Am learning a great deal during this buildimage upload no compression
image hoster
Hi Chris, the gun has some nice detail, looking good.
Chris, that is looking great!
