Brad--that spring hack looks WORLDS better than the kit's option. I will also try this.
I'm having an issue re-creating the same exact effect (see below).
My kit got here and the barrel had been de-spued with a machete, and then left to sit in a puddle of glue. It's HOSED. But. I am keeping calm and carrying on and trying to overcome it. SLOWLY.
Ouch! That sucks. I see that Trumpeter replacement parts has sprue "A" available (thru AliExpress) but it's about $12 + shipping. Not sure it's worth it given the fairly low cost of the kit.
I have glued it and gotten it true. Now I have a few layers of putty drying to fill the seams/damage, and I'll try to clean it up this week while at work on con-calls. Almost no hope of getting it started, let alone done for this campaign.
That's a bummer. I was hoping someone else would build this and show me how it's done
But I'm glad you got it for free. Took me a second to understand AFU... was thinking some sort of Artillery Fire Unit?
At least I'm not a total loss and I did discover it's just a relative of FUBAR.
So speaking of hosed... here is an update on my M198. I did have to think long and hard about this - I was going to simply lie and hope nobody would notice.
BUT.... I've made a number of mistakes on this and I thought I'd just carry on but then I discovered my biggest mistake yet:
Careful observation will reveal that on the upper assembly, I have the barrel nearly 1/2" to the left. I tried to fix it but I seem to have secured things
really well.
So showing that I have more money than common sense, I cracked open the second kit and started over. I figure I'll use most of the first kit as a paint mule and will buy a 3rd kit to build later (and hopefully visibly show how my skills have improved).
I'll say here that most of the problems I've had here are my fault - they kit is very nicely done. But there are a couple of things I'm pretty sure aren't my fault:
1. There is more flash on the 2nd kit, tiny amounts on the mating surfaces - annoying!
2. Some of the peg/slot connections are
really tight. I had to enlarge some slots to allow the parts to fit (C39 as an example off the top of my head). So make sure you dry fit always (no big shock with that advice, right?)
I do need to practice as both attempts to cut off part A18 and clean the sprue connection mark failed and I "de-rounded" the part (man this thing has some
tiny parts).
Be careful when placing part C15 making sure it's level... it needs to be able to connect to the slot in A12. One of my was placed crooked and looks odd (might be able to fix that). And if you're building the gun deployed C15 fits into A12 (so if there is a mismatch it's a problem)
Also I think I've seen this mentioned in reviews but be careful of part C35 - it limits the travel of the "legs". I'd suggest waiting on adding this part until the end (after the "legs" are set in position).
I'm really hesitating to add much about my problems because... well I'm an idiot and have no idea what I'm doing. Heck I'm still amazed at how much better the parts look after you remove the EPMs, sink marks, and seam lines (seems like every round part in this kit has at least a faint seam line).
Sorry to babble... here are some pictures of the re-work.
Sorry for the poor quality - I'll hopefully add a bit of lighting soon.
I'm kinda bummed I had two tries to correctly remove the sprue "stub" from A18 (I trimmed just a bit too much). And I'm still making too many mistakes but...
It
looks like an M198... almost ready for primer and paint. Hopefully I can hide most of my sins with dirt
Brad.
