Building Trumpeters 1/16th Panther G
KitMaker: 2,663 posts
Armorama: 2,649 posts
Posted: Friday, January 18, 2019 - 08:58 AM UTC
I have a little more finished today.
First the Jack and its mounting.
It's just test fitted.
Posted: Friday, January 18, 2019 - 09:05 AM UTC
Posted: Friday, January 18, 2019 - 09:12 AM UTC
I checked back it looks like the Transmission Pics. are no longer available.
Well any way that's all for now.
Donald
Posted: Saturday, January 19, 2019 - 08:16 AM UTC
Posted: Saturday, January 19, 2019 - 08:24 AM UTC
New South Wales, Australia
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Sunday, January 20, 2019 - 01:37 AM UTC
Posted: Sunday, January 20, 2019 - 05:06 AM UTC
I'm glad that you like it, I try to find the best way to get it together. This way I catch most of the mistakes or fit problems before you get to it.
Fore example Trumpeter uses the Engine from their Tiger II kit, the end of the plug on the Drive shaft needs to be cut almost in half to get it to fit the Tiger II Engine otherwise the shaft is too long.
Well that's coming up next.
Donald
Posted: Sunday, January 20, 2019 - 05:10 AM UTC
Posted: Sunday, January 20, 2019 - 05:14 AM UTC
Posted: Sunday, January 20, 2019 - 05:24 AM UTC
Posted: Sunday, January 20, 2019 - 05:31 AM UTC
I'll be working on the Ammo Bins next.
Regards.
Donald
KitMaker: 730 posts
Armorama: 624 posts
Posted: Sunday, January 20, 2019 - 05:53 AM UTC
Fascinating build, and excellent progress!
Thanks for sharing.
Dave
"No beast so fierce but knows some touch of pity.
But I know none, and therefore am no beast."
KitMaker: 184 posts
Armorama: 183 posts
Posted: Monday, January 21, 2019 - 07:22 AM UTC
Donald,
Your build looks fantastic so far and it is really interesting to see this big cat come to life!
Your thoroughly detailed build thread is an ENORMOUS gift to anyone who is going to tackle this monster.
It's a really great resource you are creating here.
Keep up the good work!
Jim
Posted: Monday, January 21, 2019 - 09:46 AM UTC
Donald,
Jim
You are too kind Jim, I'm just trying to help others that might try this build.
I bet Mr. Sam Dwyer ( Most likely spelled wrong) could do a better and more detailed one , like his King Tiger build.
Regards.
Donald
Posted: Monday, January 21, 2019 - 09:49 AM UTC
OK now to the Ammo Bins.
The Side deviders have some push pin marks that may be visible and need filling before assembly.
Test fitted & tac glued in place.You should place in the Hull and finish gluing the Bins to the Floor piece.
(just don't glue them to the Hull yet)
Here the side deviders are test fitted.
Posted: Monday, January 21, 2019 - 09:57 AM UTC
Painted, (Note The Floor piece slides under the Handle on the Firewall)
None of this is glued in yet, that will happen after the Ammo is installed.
I'm working on that next, and that looks like it might take a while.
Regards.
Donald
Vermont, United States
KitMaker: 3,569 posts
Armorama: 2,070 posts
Posted: Tuesday, January 22, 2019 - 03:44 AM UTC
Donald,
Jim
Regards.
Donald
Sam Dywer did the Jagdtiger, David Parker of AFV Magazine did the Kingtinger "Superking", but the feeling is seconded. Your build here points out a LOT of things I am going to need to know to tackle one of these beasts!
If you can keep your head when all about you are losing theirs,
perhaps you've misunderstood the situation.
Posted: Tuesday, January 22, 2019 - 10:14 AM UTC
Hey Guys, here's a Heads Up.
The Ammo Rounds are really a B---H.
Heavy seam marks, and some sink marks by some of the gates.
It's funny but I think some how some of the rounds are partially hollow. I found that while drilling for the holders the drill would suddenly hit an empty spot.
Well enough Jabbering.
Here's what I have so far.
You'r not going to see any of the bases.
Now to clean and paint them.
Donald
Posted: Wednesday, January 23, 2019 - 07:11 AM UTC
I have the Gloss Black Primer on them, tomorrow I'll paint the Brass.
I hope this works.
Donald
Posted: Saturday, January 26, 2019 - 05:53 AM UTC
I have the Ammo finished and ready for installation.
I used Tamiya Gloss Black for the primer, I think it gives the Brass color a deeper hue.
I used Model Master Brass Metalizer for the Brass color.
This is not mine I found it on the Web.
Finished for now.
Donald
ColinEdm
Associate EditorAlberta, Canada
KitMaker: 1,355 posts
Armorama: 1,229 posts
Posted: Saturday, January 26, 2019 - 11:47 AM UTC
Egadz! That's a lot of shells to paint...not looking forward to doing them on my RFM cutaway kit. Great build as usual Donald!
The voices are back.....excellent....
KitMaker: 23 posts
Armorama: 22 posts
Posted: Saturday, January 26, 2019 - 04:50 PM UTC
Donald
Is this about the same technique you used on your 1/16 Panzer IV build that you did awhile back? It looks similar but my memory is failing. I seem to remember your use of the glossy black primer then.
John
Posted: Saturday, January 26, 2019 - 10:15 PM UTC
Donald
John
I'm not shure, I was going to use this other Brass finish but I was out of it. I think this worked out even better as the Gloss Black covered most of the sanding scratches.
The Model Master Brass Metalizer can be used on the bare plastic, but then you'll have to polish out all the sanding marks. This is a lot easier. Just be shure to let the Tamiya Gloss cure for at least a day.
I din't know if this would work on Gloss Enamel as the Metalizer is a Laquer , it needs to be sprayed it doesn't brush well.
Regards.
Donald
Posted: Saturday, January 26, 2019 - 10:40 PM UTC
Thanks, there are 85 Rounds here it was bad enough doing them in 1/16th. scale, in 1/35th. Not me No No No.
Regards.
Donald
Posted: Sunday, January 27, 2019 - 05:14 AM UTC
I have the Rounds installed in the verticle boxes. As you will see from the pics. there's no need to get too fussy with the bottom ends of these , except for the 3 that go in the bittom of the lower hull they can't be seen.
You will have to put a slight bevel on the bottom sides of the holes in the retaining parts.
Insert the ammo rounds one at a time so they sit evenly and glue through the bottom hole using liquig glue.
It should look like this.
