KitMaker: 944 posts
Armorama: 928 posts
Posted: Wednesday, September 23, 2020 - 01:58 AM UTC
Love the progress you make... That fish must be deaf and blind!!!
On the serious side, do add the carrier in time! the tracks, wheels ,and possibly, rear of the vehicle must be submersed!!!!
Hi Erwin,
Deaf and blind...and definitely dumb,
...think I modelled him on myself,
I have given the Carrier its basic green coat, so working on it.
Luckily, because of how Carriers sit on their tracks, and because of the location I picture it in, no track in contact with the surface sits in water, but a reasonable length will overhang it and be subject to splashes etc. Hopefully that comment will make more sense as the build progresses,
G
An optimist is a pessimist without all the facts.
KitMaker: 944 posts
Armorama: 928 posts
Posted: Wednesday, September 23, 2020 - 02:13 AM UTC
Hi all,
Very little progress over the last few days to report, but work still proceeds,
Looking at images of cascading/flowing water there is a lot of turbulent, bubbling whiteness and I have been trying to find a way of doing this.
Initially I tried painting it on with white oils 'pin-pricked' into the surface of the water, plan 'A'...a bit like tattooing...but, imho, it didn't look right, especially once it had dried, so it was back to the drawing board.
The images below show plan 'B', believe it or not, it does, imho, look considerably better than painted on,
The Carrier has also had its first coat of 'green'.
G
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Wednesday, September 23, 2020 - 02:57 AM UTC
Welllll...looks convincing to me! For sure.
J
New South Wales, Australia
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Wednesday, September 23, 2020 - 03:21 AM UTC
Me too - I don't pretend to know how the water/acrylic is applied but I had another crazy thought for bubbles - inject a hyperdermic into it when wet, either pump air or water or something that'll make it froth?
KitMaker: 944 posts
Armorama: 928 posts
Posted: Thursday, September 24, 2020 - 03:55 AM UTC
J
Hi Jerry,
Thank you for your reassurances,
G
KitMaker: 944 posts
Armorama: 928 posts
Posted: Thursday, September 24, 2020 - 04:06 AM UTC
Hi Tim,
Thank you,
The acrylic I've been using is poured in thin layers, 3mm depth at the most each time. It then takes at least 24hrs before the next layer.
I'm no expert as it's my first ever attempt at water of more than a few mm's as used in the water trough on my snowy diorama, so it might work. However, I think the bubbles would rise out, especially the number you'd need to represent turbulent waters, if put in too early, and would force the surface to balloon if put in once it has skinned over.
But, as I say, I'm no expert, maybe someone has tried it and could comment on their experience(s)?
G
KitMaker: 944 posts
Armorama: 928 posts
Posted: Thursday, September 24, 2020 - 04:14 AM UTC
Hi all,
Thought I best spend the next few days painting up the Carrier so that I can incorporate it into the last few layers of water.
I've started to give it some tonal variation (see images below).
I still need to add some oil washes to create more contrast, also the camouflage net and holder need painting, plus the addition of some decals, crew and stowage...so a long way to go just yet,
G
Posted: Thursday, September 24, 2020 - 05:42 AM UTC
Carrier looks the biz so far.
KitMaker: 380 posts
Armorama: 366 posts
Posted: Friday, September 25, 2020 - 04:24 AM UTC
Noord-Holland, Netherlands
KitMaker: 1,757 posts
Armorama: 914 posts
Posted: Friday, September 25, 2020 - 05:22 AM UTC
Somehow I imagined that the water would be deeper... Hence my remarks..
It looks great, though I have one remark: the upper level of the fall would only have froth if any obstacle would be present. Which in this case doesn't seem to be present?
Ex- PFC Erwin Leetink, RNLA
Napoleon Bonaparte:
"A soldier will fight long and hard for a bit of colored ribbon."
KitMaker: 2,185 posts
Armorama: 1,813 posts
Posted: Friday, September 25, 2020 - 08:26 AM UTC
Cool G , love it !!
Whole new perspective with the carrier added .
KitMaker: 944 posts
Armorama: 928 posts
Posted: Wednesday, September 30, 2020 - 04:25 AM UTC
Hi Jerry,
Thank you for the kind feedback,
G
KitMaker: 944 posts
Armorama: 928 posts
Posted: Wednesday, September 30, 2020 - 04:27 AM UTC
Hi Ski,
Thanks, much appreciated,
G
KitMaker: 944 posts
Armorama: 928 posts
Posted: Wednesday, September 30, 2020 - 04:37 AM UTC
Hi Erwin,
As previously mentioned...and I could be wrong, again,
...if it was deeper I imagined that the downstream cascade wouldn't occur...but I'm no expert, as my next sentence will demonstrate,
It would seem that you are right regarding the upper level, I have looked at a number of pictures and there only appears to be turbulent water at the 'fall' side,
. I imagined, wrongly, that the deeper water hitting the ford stonework would force the water upwards, thus causing turbulence on the surface.
Lesson learnt,
, I will see if I can lessen the effect when I put the wavy surface on.
G
KitMaker: 944 posts
Armorama: 928 posts
Posted: Wednesday, September 30, 2020 - 04:39 AM UTC
Cool G , love it !!
Hi Cheyenne,
Thank you, glad you're liking it,
G
KitMaker: 944 posts
Armorama: 928 posts
Posted: Wednesday, September 30, 2020 - 04:52 AM UTC
Hi all,
Not had chance to do anything this past week due to outdoor stuff needing doing as Autumn (Fall) approaches, but the weather turned wet and windy today, so a return to painting the Carrier (see images below).
It's knowing when to stop adding high and lowlights on this type of vehicle as much of the paintwork will be hidden under crew, dirt and stowage.
The gap between the vertical front plate and the driving/gunners compartment sidewalls is not an error,
...honest,
...it's that I haven't yet glued them in position until the crew are installed,
G
Armorama: 914 posts
Posted: Wednesday, September 30, 2020 - 08:38 PM UTC
Ah, we are al here to learn from eachother and to learn from our own mistakes, aren't we?
We not only share our work to get compliments (however nice they are), but to see if we are on the right track... And mostly, I think you are!!! To give an extra tip: AK wet effects works very nice to recreate the wet tracks/wheels/etc. Better than varnish...
Napoleon Bonaparte:
KitMaker: 944 posts
Armorama: 928 posts
Posted: Friday, October 02, 2020 - 03:35 AM UTC
Hi Erwin,
Indeed we do, though I was certain I'd seen a photo showing something similar, and when I looked back I found it was one of the images that had inspired me in the first instance (see image below).
Whilst it's not as excessive of mine it does mean I'm happy to stick with a little whitewater at the top edge of the ford.
Thanks for the tip on the 'wet effects', I might give it a try,
Thanks again, and cheers,
G
KitMaker: 944 posts
Armorama: 928 posts
Posted: Friday, October 02, 2020 - 03:53 AM UTC
Hi all,
Started today to give some thought to the crew, especially the driver as I can't fit the front plates until he's done.
I had intended to use the Tamiya driver as he comes but he sits too low, imho, within the 'cockpit'. If used 'as is', he wouldn't be able to see as the vision ports are not openable on the kit.
Having looked at several images it's not uncommon to find a driver with his head almost popping up over the parapet. I believe the gunner's seat was adjustable, heightwise, though the drivers seat doesn't look as if it is,
. However, I have tried raising the legs slightly, and used a longer torso to get a higher position.
I have also started to think about the stowage and have begun adding bits and bobs to the rear of the Carrier. One of my pet hates is plastic tarpaulins, so have ignored the kit supplied one and made one from paper and white glue (see images below).
G
KitMaker: 978 posts
Armorama: 965 posts
Posted: Friday, October 02, 2020 - 04:59 AM UTC
I probably sound like a broken record when it comes to British Army kit (or other nations for that matter) but don't forget the rifle slings.
All looking very good Gareth - especially the water effects - a practical tutorial for all to benefit from. Keep at it!
Brian
Posted: Friday, October 02, 2020 - 01:25 PM UTC
Hey G it looks like just you & I didn’t get the memo…did the other builders get entrapped in the beta forums this week? Great work on the carrier & tarp (passing a flame fast – real fast – over the tarp would remove any furriness), weathering’s ideal - maybe a couple of random oil/stains & a fender-ding too? Always wondered how this vehicle was introduced for field trials…”Yes Generals we’ve designed a (s)lightly armoured vehicle in which in an ambush situation only the crews heads will get blown off. And we recommend it’s only deployed in flat desert terrain, so that the enemy’s fire passes over horizontally and can’t set off any munitions being transported.” “Jolly good we’ll take two thousand”.
Crazy idea #94: Depending on how long the “water” takes to cure, you could apply a layer, put the dio on top of a washing machine & set it to extended spin-cycle - instant rippled effect
KitMaker: 1,112 posts
Armorama: 886 posts
Posted: Friday, October 02, 2020 - 09:54 PM UTC
Nothing constructive to add, just still following along and liking everything you done so far. Keep it up.
Posted: Saturday, October 03, 2020 - 02:31 AM UTC
The layers of detail you are adding to the carrier are lookin good man. I like the way your paper tarp "folds" and it looks the bill in that regard. Maybe find a way to remove the fuzz as Martin says? It does give the impression of being a large blanket right now.
I am still taking notes and continue to be impressed by your "waterworks",
J
KitMaker: 380 posts
Armorama: 366 posts
Posted: Saturday, October 03, 2020 - 06:07 AM UTC
Hey, the water works is looking great! Ruck On bby!
KitMaker: 944 posts
Armorama: 928 posts
Posted: Sunday, October 04, 2020 - 12:19 AM UTC
Brian
Hi Brian,
Thanks for the positive feedback, and you're not sounding like a broken record, it's always good to be kept on the straight and narrow by the good folk in here,
G
