The picture is an excellent source for what a Pather muzzle brake will look like after firing the gun a few times, not what the entire tank will look like. The muzzle brake has the paint blasted off by the firing of the gun.
Look past the muzzle and at the Panther just behind it. In particular look at the mess tin hanging on the turret. It has paint chipped, or burnt or scraped off down to bare metal. No where on the tank itself can be clearly seen the same type of damage to the zimmerit as to the muzzle brake or the mess tin. The reflection of the bare metal shows on the muzzle brake, the mess tin and on the leading edges of the tracks. I tried to find a clearer copy of the picture, but no luck.
I am still willing to bet that the upper deck, where the crew walked, would be badly worn by the hob nails.
Randall,
I used the pic because it shows "polished" bare metal which is what people are going to think of when I use the term "bare metal" - yes the percusive effect of firing the weapon is obviously what caused the wearing (red oxide, does have it's limitations - obviously) and it should also NOT be considered indicative of what every muzzle brake will look like - but others say "i don't see any evidence anywhere else" -
I say "I choose to see evidence EVERYWHERE"
B/W photos are not necessarily the best source for what we are trying to illustrate - and certainly not unless they are close up.
B/W pics do serve their purpose tho'
And as I said before - if you don't believe that vehicles being subjected to this sort of treatment don't suffer some adverse effects - then nothing I say will change anyone's mind.
Greg
