Jesse: nice pose on the figure. Are you planning to have a few more up on the roof scouting out the area ahead?
Happy Modelling, -zon
Urban Warfare Campaign
zontar
Hawaii, United States
KitMaker: 1,646 posts
Armorama: 1,557 posts
Posted: Sunday, April 24, 2011 - 04:45 PM UTC
melonhead
Wisconsin, United States
KitMaker: 662 posts
Armorama: 457 posts
KitMaker: 662 posts
Armorama: 457 posts
Posted: Monday, April 25, 2011 - 05:40 AM UTC
i thought i had a good one lined up. but then realized the uniform wouldnt match anything else. so, it would look completely out of place and i dont have anything else that would match. plus, i dont really want to overcrowd things with too many figures.
beefy66
KitMaker: 971 posts
Armorama: 280 posts
KitMaker: 971 posts
Armorama: 280 posts
Posted: Tuesday, April 26, 2011 - 09:58 PM UTC
Small update on my factory wall, I,ve added the roof buy using tin foil shaped over some skewer sticks cut down and glued to a scrap piece of plastic card. Also made a wall lamp from copper rod tin foil cover and a LED bulb from an old circuit board added some rubble and bricks to the base where the wall has been hit. Also have done washes and pigments to the storage tank
Still need to make up some wood pallets and find some kind of machinery stuff to have lying around maybe some tractor parts
zontar
Posted: Sunday, May 01, 2011 - 06:54 PM UTC
Jesse: I hear you on the figures. Maybe just some "roof junk" then to keep the space from being too empty.
Keith: Looking good. I really like how the tank turned out.
mmeier
Nordrhein-Westfalen, Germany
KitMaker: 1,280 posts
Armorama: 1,015 posts
Posted: Wednesday, May 04, 2011 - 09:42 AM UTC
It has begun:
There will be a Dragon Pak-40 in the lower part of the house (build started) and some infantry in the upper floor.
zontar
Posted: Wednesday, May 04, 2011 - 04:35 PM UTC
MBR: coming together well.
I have begun my building for my Iraqi street diorama.
Still have a bit more to do with the foam core, then I'll start with the chipboard and cork.
vonHengest
KitMaker: 5,854 posts
Armorama: 4,817 posts
Posted: Wednesday, May 04, 2011 - 05:54 PM UTC
Looking forward to seeing more of your scratchbuilding techniques at work Zon
meaty_hellhound
KitMaker: 786 posts
Armorama: 753 posts
KitMaker: 786 posts
Armorama: 753 posts
Posted: Thursday, May 05, 2011 - 02:10 AM UTC
looking good Zon, that's a really nice design of a building. looking forward to seeing it come together. cheers, bd.
exer
Dublin, Ireland
KitMaker: 6,048 posts
Armorama: 4,619 posts
Posted: Thursday, May 05, 2011 - 06:52 AM UTC
Looks great- very neat job. I'm looking forward to seeing this come together.
Herper55
Missouri, United States
KitMaker: 37 posts
Armorama: 30 posts
KitMaker: 37 posts
Armorama: 30 posts
Posted: Thursday, May 05, 2011 - 09:16 AM UTC
Everyone is doing really well . I have just started to order some stuff.
zontar
Posted: Thursday, May 05, 2011 - 04:11 PM UTC
Thanks for the comments guys!! Hopefully more this weekend.
beefy66
KitMaker: 971 posts
Armorama: 280 posts
KitMaker: 971 posts
Armorama: 280 posts
Posted: Saturday, May 07, 2011 - 01:02 AM UTC
Great work so far Zon, Here is my progress so far need to make a sign for where the patch on the wall is and touch up some of the wall where the tape has took off the paint
Also need to add some gloss to where the tank traks have been to make it look wet
ltb073
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Saturday, May 07, 2011 - 03:36 AM UTC
some great stuff coming along here, my project has been sidetracked a little the past 2 weeks should get moving more on it tomorrow or Monday
@ Zon, your scratch building is looking good cant wait to see it completed
@ Keith, love your winter scene there what did you use for the snow
beefy66
KitMaker: 971 posts
Armorama: 280 posts
KitMaker: 971 posts
Armorama: 280 posts
Posted: Saturday, May 07, 2011 - 04:19 AM UTC
Thanks Sal the snow is from a model railway store it is from a company called Modelseinics they also do some other stuff you can use in Dio making, like grass scater and trees and water gels. There is also another company called Delux Materials that do a graet range of stuff for dioramas
Cheers Keith
Cheers Keith
VLADPANZER
Lebanon
KitMaker: 568 posts
Armorama: 549 posts
KitMaker: 568 posts
Armorama: 549 posts
Posted: Monday, May 09, 2011 - 02:21 AM UTC
Hi all,
MBR: Good start, what’s that diorama in the corner?
Zon: Great layout, may I ask what material your using?
Keith: Nice work, what sign are you thinking of putting?
mmeier
Posted: Monday, May 09, 2011 - 04:47 AM UTC
Hi all,
That is MiniArts "Village Workshop". In this case it is occupied by a field kitchen brewing and will also show the horses being led to graze. I'll see if I have some shots. I had the field kitchen build and then "sitting around" and wanted to try one of the "Diorama in a box" kits.
zontar
Posted: Monday, May 09, 2011 - 01:24 PM UTC
Keith: your dio has come out really well! A great backdrop for your T-34. Nice. I wasn't expecting a winter scene, so that is also a nice surprise.
Sal: Thanks for the comments.
Vlad: I used Foam Core, which is a layer of foam sandwiched between two paper faces. Here they sell it at Wal-Mart as a type of poster board. It should also be available in art/architecture supply shops and possibly picture framing shops. I printed the building layout on paper and used spray adhesive to glue it onto one side of the foam core, then cut out the pieces. Change your blades often as the foam/paper combination dulls blades quickly. I will glue it together with white glue (PVA) Also the foam can dissolve if exposed to some spray paints and paint solvents. Acrylics are safe to use. HTH.
mmeier
Posted: Monday, May 09, 2011 - 03:22 PM UTC
and the Pak-40
beefy66
KitMaker: 971 posts
Armorama: 280 posts
KitMaker: 971 posts
Armorama: 280 posts
Posted: Wednesday, May 11, 2011 - 10:36 PM UTC
Thanks for the comments Guys
Do any of you have a suggestion as to what sign I could use for the wall say something like a factory sign that says " engine block" or similar.
MBR how did you find the build up of the wall and shed I have the farmhouse set with that wall to like the paint and whaether job you have caught on it
Cheers Keith
Cheers Keith
mmeier
Posted: Thursday, May 12, 2011 - 02:40 AM UTC
I have played around with a number of highly diluted acrilic paints.
+ Base is Tamiya "Dunkelgelb", thinned with Tamiya X20A at least 1:3 and applied in two coats
+ Over that I applied a glazing of Vallejo "German Green" (at least 1:10)
+ Roof is done in Vallejo "Red", some schindles picked out with the base color either lightened with Vallejo "Khaki" or darkened with Vallejo "German Grey" (The color used on the kitchen etc). Same for the bricks
+ Bricks got the same glazing as the walls
+ Grass was painted with a green tone. After that covered with white glue (Holzleim) and "gras" for railroad modelling. Over that some "Future"
+ Walls, roof and bricks got a final glazing of 1:10 diluted "German Grey", carefully "scrubbed down" to remain mostly in the cracks.
ltb073
Posted: Monday, May 16, 2011 - 04:54 AM UTC
Ok guys finally made some progress that you can actually see doors and windows are on
Stared to scratch a small section of the second tier roof out of balsa wood and scrap plastic from the Mini-Art kit
I don't what to big of a roof cause there will be figures on the inside. Hopefully I'll get some more done tomorrow
zontar
Posted: Monday, May 16, 2011 - 06:02 PM UTC
Sal: looking good. Nice choice with the metal shingles.
zontar
Posted: Tuesday, May 17, 2011 - 02:25 PM UTC
I've started corking my building, so in the meantime, I thought I'd throw out a teaser...
zontar
Posted: Friday, May 20, 2011 - 05:41 PM UTC
Aloha All:
Got Cork! Next will be to fill in the grout joints with wall spackle then get to some of the inner surfaces and the balcony before putting the structure together. I've ordered the stock for the windows and doors.
Posted: Saturday, May 21, 2011 - 07:07 AM UTC
hey guys there all looking good so far
i have made a start on mine, its the first time i have used cork for bricks so its not the best but im happy overall with my progress and the way its turned out
not the best angle but it gives an overall look its ment to be a russina hospital
im planning on it being a four base build and have started the second which includes three shops and the other two base are a park and a row of Terence.
houses
hope you like it so far comments good or bad welcome
houses
