Anti-Aircraft
PantherF
Indiana, United States
KitMaker: 6,188 posts
Armorama: 5,960 posts
Posted: Sunday, March 10, 2013 - 10:32 AM UTC
Well then we must see it?
~ Jeff
Nito74
Lisboa, Portugal
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Sunday, March 10, 2013 - 11:14 AM UTC
~ Jeff
It's not on the photos, I get it. sorry.
kruppw
KitMaker: 1,117 posts
Armorama: 1,115 posts
Posted: Sunday, March 10, 2013 - 11:21 AM UTC
zsu is actually in the box with the rest of the parts. The zsu actually came from my mt-lb by the same company. I'll take pictures of it later.
kruppw
Posted: Sunday, March 10, 2013 - 11:30 AM UTC
Here you go jeff the zsu parts
Lakota
#123
New Mexico, United States
KitMaker: 1,202 posts
Armorama: 635 posts
Posted: Sunday, March 10, 2013 - 01:05 PM UTC
Howdy Y'all:
Here is the kit I'll be working on. I don't know if I'll use the aftermarket barrels. They look small, intricate and my carpet monster is hungry.
Y'all take care,
Don "Lakota"
darreng
KitMaker: 789 posts
Armorama: 382 posts
Posted: Monday, March 11, 2013 - 12:40 AM UTC
Hi guys. I've hit a stumbling block on my build. Exhaust colour. I was thinking thinking of painting it steel and then rusting with weathering powders. Would this work? Or is steel too bright, and paint it Humbrol 113 Rust?
Shuftie
Western Australia, Australia
KitMaker: 74 posts
Armorama: 42 posts
Posted: Monday, March 11, 2013 - 01:01 AM UTC
Hi All
Am starting to work on my Gaz AAA anti-aircraft truck.
Stephen
asmodeuss
Quebec, Canada
KitMaker: 1,389 posts
Armorama: 1,388 posts
Posted: Monday, March 11, 2013 - 01:03 AM UTC
Hi Darren, I would go with something dark and then rusting it with whatever you want. I usualy start with a preshaded exhaust then apply a base coat of xf-56 mixed with xf-10 flat brown 50/50. Afterward I use pigments. The darker color give the depth.
Anyhoo, here is where I am at:
I got the tire done
tire01 par asmodeuss, sur Flickr
tire03 par asmodeuss, sur Flickr
Some of the hull..I`ll change the chain that i`ve glued...it`s too short imo.
hitch02 par asmodeuss, sur Flickr
The front suspension was easy and required only a small modification to fit properly.( tires not glued) HAaaaa Dragon kits, always an adventure
front susp01 par asmodeuss, sur Flickr
More soon People!
Phil.
PantherF
Posted: Monday, March 11, 2013 - 01:08 AM UTC
Well Darren, exhaust is an acquired taste as each have their own approach to it. Take a few tips or examples and practice as each will give a different result.
A few I have tried, painting the exhaust a primer or dark color and then apply RUSTALL to the required result.
AND then I have used the salt technique where you paint the exhaust the color of the vehicle and allow to dry. Then lightly sand that area down and get it wet. Using Sea Salt get enough of the salt to stick, and then let it dry. Using the color of exhaust (some sort of light brown) lightly coat the area where the salt is. After allowing that paint to dry, carefully knock off the salt and the undercoat of the vehicles paint will show.
These are just a few of MY examples I have tried. Sometimes just a combination of each works too but the best way to find out is to experiment before working on your model.
Also, look here on ARMORAMA for the techniques to achieve those results you want.
HTH
~ Jeff
Joel_W
AUTOMODELER
KitMaker: 11,666 posts
Armorama: 1,143 posts
Posted: Monday, March 11, 2013 - 01:29 AM UTC
Darren, I prefer a base color of Tamiya Hull Red XF-9. then I dry brush on graphite from a pencil. Finally I highlight by dry brushing a brighter aluminum shade the end of the exhaust.
Joel
robw_uk
KitMaker: 1,224 posts
Armorama: 1,207 posts
Posted: Monday, March 11, 2013 - 03:10 AM UTC
some great progress over the past few days - none from me I am afraid ;-) more next week.....
Nito74
Lisboa, Portugal
Posted: Monday, March 11, 2013 - 04:39 AM UTC
Well, I usually giva a first coat of steel (Humbrol 27004) then give several layers of rust (either AK Rust streaks, pigments or Humbrol 113, or a combination of those, depends on the effect I want to create.)
Test it first on some bare plastic, old kit,since you can create different rust tones.
Nito74
Lisboa, Portugal
Posted: Monday, March 11, 2013 - 04:41 AM UTC
oops, forgot my update...
Several sub-assemblies
BBD468
KitMaker: 2,465 posts
Armorama: 2,383 posts
Posted: Monday, March 11, 2013 - 05:09 AM UTC
Hello fellas,
I have completed step no.1.
Movin' along John...looks nice!
Gary
darreng
KitMaker: 789 posts
Armorama: 382 posts
Posted: Monday, March 11, 2013 - 11:22 AM UTC
Looking good there buddy!
I haven't done much on the h/t today. As you can see below.
Lakota
#123
Armorama: 635 posts
Posted: Monday, March 11, 2013 - 01:39 PM UTC
Howdy Darren:
I never paint the exhaust the same way. There always seems to be something new and cooler (no pun intended). My latest project is using Panzer Colors three exhaust colors. I also like using the Tamiya Red-Brown previously mentioned. Next I'll have to try that salt method.
Take care,
Don "Lakota"
darreng
KitMaker: 789 posts
Armorama: 382 posts
Posted: Monday, March 11, 2013 - 11:59 PM UTC
Thanx everyone for the different methods on doing the exhaust. I have another question. Can I use decals from a scrapped Trumpeter build to put on the engine block?
Joel_W
AUTOMODELER
Posted: Tuesday, March 12, 2013 - 01:18 AM UTC
Why not? It's added detail.
Joel
asmodeuss
Quebec, Canada
Posted: Tuesday, March 12, 2013 - 01:20 AM UTC
Joel
If it fits, I would
darreng
KitMaker: 789 posts
Armorama: 382 posts
Posted: Tuesday, March 12, 2013 - 01:33 AM UTC
Ok thanx guys. There'll be an update later.
asmodeuss
Quebec, Canada
Posted: Tuesday, March 12, 2013 - 02:00 AM UTC
SWEEEEET!
Pytagoras
Møre og Romsdal, Norway
KitMaker: 300 posts
Armorama: 285 posts
Posted: Tuesday, March 12, 2013 - 04:47 AM UTC
Looks like getting a replacement upper hull is going to take some time (5 days between replies from Dragon Care), so my Flakpanzer V Coelian won't be started until that mess is sorted out.
Nito74
Lisboa, Portugal
Posted: Tuesday, March 12, 2013 - 09:54 AM UTC
@Gary
Thanks ! this 1970's flak is pretty shake&bake kit, all sub assemblies are done.
Nice start with the chassis & suspension, watch out for those instructions.. looking forward to see another perfect build...
darreng
KitMaker: 789 posts
Armorama: 382 posts
Posted: Tuesday, March 12, 2013 - 11:10 AM UTC
Some progress.
1721Lancers
KitMaker: 1,673 posts
Armorama: 1,640 posts
Posted: Wednesday, March 13, 2013 - 04:51 AM UTC
@Phil: coming along very nicely as always mate
@John: hi there, that build will be probably be finished in a couple of days, knowing the speed that you go at
@Gary: nice `n´clean as always dude, just how much mind power do you have? You can´t see a hint of glue anywhere
@Darren: like it, looks cool, the engine also. I also choose
Tamiya hull red as the base rust color, and work on it from there. I use enamels and ground up chalks, but never the same procedure.
Well here you go build side finished, base coat tomorrow:
