Rapid Reconnaissance Campaign
exer
Dublin, Ireland
KitMaker: 6,048 posts
Armorama: 4,619 posts
Posted: Friday, June 14, 2013 - 06:19 AM UTC
Coming together nicely john
Nito74
Lisboa, Portugal
KitMaker: 5,386 posts
Armorama: 4,727 posts
Posted: Friday, June 14, 2013 - 06:48 AM UTC
Thanks Pat !
I also found some photos of the real thing, only 70 were built.
I was trying to find a photo since I noticed some different boxes from the Italeri kit and other builds
Italeri stowage box
ElCapitan
KitMaker: 219 posts
Armorama: 217 posts
Posted: Friday, June 14, 2013 - 11:49 PM UTC
John,
Your build is coming along nicely and the those photos of the real vehicle are some of the first ones I've seen of that vehicle. Pretty cool.
steph2102
Isere, France
KitMaker: 735 posts
Armorama: 606 posts
Posted: Saturday, June 15, 2013 - 01:49 AM UTC
hello,
some progress with the set painting inside. I think I will not put the driver (it takes too much space).
steph
1721Lancers
KitMaker: 1,673 posts
Armorama: 1,640 posts
Posted: Saturday, June 15, 2013 - 06:53 AM UTC
Steph that looks realy good my friend.
Kevin fantastic dude, and the figure painting is brill.
John your build is coming along nicely, and thanks for the real deal pics.
Thanks John (jkb) but your going to have wait a bit more before anything goes any further
I´m going to have to repaint my Scimitar, as the Tamiya
clear I used turned into a nightmare. Maybe some pics tomorrow
geogeezer
Arizona, United States
KitMaker: 263 posts
Armorama: 258 posts
Posted: Sunday, June 16, 2013 - 06:32 PM UTC
Hi all
Steph Looking good. Great interior detail.
John That's a very interesting tank. Looking forward to seeing it finished.
The M8 is nearly finished. Got the Brazilian decals on, and a little weathering done. I replaced the kit's tow cable with one made of picture wire, which was tightened up a little by chucking one end in a hand drill and clamping the other in a vise. I had some difficulty getting it to conform to the contours of the hull, but it looks better than a piece of string. The antennas were another problem. I'm a total failure at sprue stretching, so I made some out of stainless steel fishing leader, which is pretty springy. The tie-down lines are strands stripped from 7 strand beading wire, and are so thin they are very hard to see, let alone work with. I'm still not completely satisfied with the way they look. The lines have slack in them, and I need to eliminate that without tearing everything loose.
For stowage I added a few leftover packs from other kits. The tarps were made from used lens cleaning wipes, folded and rolled up. The straps are strips of masking tape.
Still to come are crew figures. Those will require the talents of Dr. Frankenstein and tools borrowed from the Texas Chainsaw Massacre. A few more finishing touches and the end will be almost in sight.
Dick
ElCapitan
KitMaker: 219 posts
Armorama: 217 posts
Posted: Monday, June 17, 2013 - 12:35 AM UTC
Steph: Making some good progress there. I'm looking forward to seeing the completed cab.
Paul: Thanks on the figure. He is made from 4 different Dragon figures with a Hornet head, so I think he came out well.
Rich: Good progress on the M8, I know how tight the turret is so good luck jamming a figure or two in there.
exer
Dublin, Ireland
Posted: Monday, June 17, 2013 - 12:45 AM UTC
Steph nice work on the Dingo- makes me want to take my one out of the stash.
Rich good progress- looking forward to the Figures. The photos look a little "Cloudy" for want of a better word, what camera are you using?
panzerbob01
Louisiana, United States
KitMaker: 3,128 posts
Armorama: 2,959 posts
Posted: Monday, June 17, 2013 - 01:44 AM UTC
Richard;
Nice M8!
I would echo Pat... those pics look a little washed-out.
Depending on the camera you are using - even many small point n shoots have some control options - you may want to consider doing one or more of the following:
1) Mount it on a tripod and use the time (delay) release if it has such.
2) Go to your mode-set and use the "Program (P)" mode which allows you to customize some settings (I suggest DON'T use the "auto" setting if you can avoid it!). When in P mode, go to your "function set" and call up the available user-changed camera functions. IF you have some White Balance options, these will change color and intensity settings for different light sources. Try some different settings to get one you like best in your pics.
3) Go to that function button and list and look at your metering options. Select the "spot metering" option which uses the center of the frame for metering. This will allow you to aim and focus your camera on different points on your model, and the camera will adjust its speed and aperture to "best expose" that targeted point. This will allow you to select the exposure point you like best to depict details and depth-of-field on your image, by moving the camera around and test-focusing (half-push on shutter release button). *In auto mode and generally, the camera meter uses most or all of the frame, and either tries to compensate for the light background or lightens the center (darker) object and ends up washing the pic with excessive background glare.
4) IF your camera and menu-options has this: Look for for a "0 +/-" icon which allows you to set aperture lower or higher than the standard metering uses. By raising the aperture number (+), you will "under-expose" (darken) your image and also gain some depth-of-field.
Just some suggestions that have helped me get some better build pics in some cases!
Cheers!
Bob
geogeezer
KitMaker: 263 posts
Armorama: 258 posts
Posted: Monday, June 17, 2013 - 11:28 AM UTC
Kevin Thanks for the comments. Jamming the figures into the turret is why the chainsaw is necessary.
Pat & Bob Thanks for the comments & suggestions. My camera is a Sony DSC P-72. The pictures were taken in filtered daylight coming through a glass door which opens onto my back porch, and the background was a white flannel pillowcase. I considered going outside where the light is better but it was 107 F here yesterday, so I'll defer that for a few more months.
I'll try a few experiments with the camera's settings and see what happens.
Dick
Dragon164
#226
British Columbia, Canada
KitMaker: 1,909 posts
Armorama: 1,066 posts
Posted: Monday, June 17, 2013 - 07:11 PM UTC
Picked this up Yesterday for the campaign.
Will probably build it OOB as I have enough PE and Resin in my other builds.
Cheers Rob.
exer
Dublin, Ireland
Posted: Monday, June 17, 2013 - 09:40 PM UTC
Cheers Rob.
Great choice Rob
Nito74
Lisboa, Portugal
Posted: Tuesday, June 18, 2013 - 02:16 AM UTC
Nice one Rob !
I did that one a few years ago.
It turns into a nice kit. Don't expect a 234 Dragon quality, but it's a really nice kit.
Here it is next to a Italeri's Puma
panzerbob01
Posted: Tuesday, June 18, 2013 - 05:55 AM UTC
Dick
[/quote]
Dick;
Taking the pics thru the door... Now that's a scenario I hadn't thought of, although I can surely understand your desires to skip the 107 f "natural environment"! That could surely contribute some "softness" to an image.
On the side; Hey, fellow "zoni"! I'm one, too! - although I claim those higher lands (Prescott and Flag for those formative years+) as my home. I suppose that you are located somewhere lower...
Cheers!
Bob
MBD
KitMaker: 84 posts
Armorama: 13 posts
Posted: Tuesday, June 18, 2013 - 06:55 AM UTC
Rob,
Glad to see someone else doing this wonder of German engineering.
Ill follow your post closely and try to pick some tips while doing mine, which is nearly ready for it....
John
obrigado for your pictures, nice one even if old ones...I hope I could do such a good work...
Dragon164
#226
Posted: Tuesday, June 18, 2013 - 11:10 AM UTC
Thanks guys!
I was surprised to find I did not have a kit for this campaign in my stash.
Cheers Rob.
russamotto
Utah, United States
KitMaker: 3,389 posts
Armorama: 2,054 posts
Posted: Tuesday, June 18, 2013 - 03:52 PM UTC
I'm in with this.
Cam
#275
KitMaker: 174 posts
Armorama: 141 posts
Posted: Wednesday, June 19, 2013 - 07:35 AM UTC
Rob - what a perfect excuse to increase the size of the stash (as if an excuse is really needed).
The chassis of my Rolls is out of the paint shop and I'm working on the interior as I want to leave everything open. Very different working on a Roden kit instead of a Dragon or Tamiya.
exer
Dublin, Ireland
Posted: Wednesday, June 19, 2013 - 08:08 AM UTC
Nice choice Russ. I also have this in my stash
Good work Cam brave choice to leave everything open
Nito74
Lisboa, Portugal
Posted: Saturday, June 22, 2013 - 11:30 AM UTC
Cam, I've always been curious about that Roden kit.
It looks great so far !
GregCloseCombat
KitMaker: 2,408 posts
Armorama: 2,394 posts
Posted: Saturday, June 22, 2013 - 06:03 PM UTC
Some nice builds going on here. I've switched to the Staghound from the 234. I can't wait to try out my first Bronco kit!
MBD
KitMaker: 84 posts
Armorama: 13 posts
Posted: Monday, June 24, 2013 - 07:32 AM UTC
Right chaps, ready to roll.
I have received the last parts I was planning to use for the campaign, the Aber PhE parts for some radios and the ugrade for the SdKfz 234/1.
Last couple of days I build three figures as crew and primed some of the body part red, as the original br />
ltb073
KitMaker: 3,662 posts
Armorama: 3,078 posts
Posted: Tuesday, June 25, 2013 - 03:07 AM UTC
Looks like some activity is picking up here
My progress
windshield section is dry fit until i finish the figures and it will get more weathering
Lonewolf7usa
Michigan, United States
KitMaker: 312 posts
Armorama: 296 posts
Posted: Tuesday, June 25, 2013 - 05:09 AM UTC
Here's an update on my Sheridan. This one's going quicker than my AAA project.
Again all comments welcome.
exer
Dublin, Ireland
Posted: Tuesday, June 25, 2013 - 05:19 AM UTC
Greg- looking forward to the Staghound.
Sal nice paintjob
Mario ineteresting to see it primed before building.
Good progress Lonewolf
