As so often I find that parts of a build which at first flush might be problematic turn out not to be and parts that should be straightforeward give you trouble.
The mudguards came from a Marquette FAI-M, bits of which I had left over from a Spanish Civil War thing I had a few years ago. Luckily they are made from quite solid plastic so making V cuts, bending and clamping to shape and then applying CA glue in large dollops worked. Lots of sanding the result and it gets close.
It was finding the mudguards that also solved the wheels problem. It occured that the prewar Russian motor industry had a lot of Ford input and I checked a drawing of the 1937 Ford V8 truck chassis with pictures of the Zvezda Gaz AAA truck kit and the wheels and chassis appear to be very close. God bless Detriot standardisation.
A friend had one and was very keen to get rid of it .
The Vickers I think is a spare Resicast barrel and the domed hatch,is a plastic scew cover.
This I had planned using early on as the size and shape were ideal but it defied all the glues in my workshop till I unearthed some strange stuff in a local craft shop. As I say its the easy one that gets you.
She is a bit battered and war weary, partly sloppy workmanship and partly by design.
The next steps are a couple of coats of Quaker Grey, the standard Irish Army colour of the 1950's and then a coating of white as one of the 8 vehicles sent to the Congo in early 1961 with the Irish contingent with the UN.
That is as soon as I can find an accurate or legible photo of such a car.
Jesper thank you for your kind words.
Paddy
