Libor, this is a great thread!
Your scratchbuilfing of the crane is top level!
Congratulations for this build
Claude
Dioramas
German WWII railway depot dio part I
roudeleiw
KitMaker: 2,406 posts
Armorama: 2,224 posts
Posted: Saturday, August 08, 2009 - 11:23 PM UTC
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Sunday, August 09, 2009 - 08:09 AM UTC
Thank you, Claude,
I do not post much, but I keep watching some interesting topics here, and I have been following your dio since beginning, very enjoyable and informative
Keep it going
Libor
Keep it going
Libor
monkybutt
KitMaker: 381 posts
Armorama: 321 posts
Posted: Monday, August 10, 2009 - 03:31 AM UTC
the attention to every single detail is incredible!
the lights you are going to mount on the warehouse- will they be real, maybe LEDs? that would be really cool
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Monday, August 10, 2009 - 08:23 AM UTC
Thanks, Andrew,
Yes, I got a few lights in HO scale with LEDs and I want to use them with some extra work to make nice lights for the warehouse and also scratch build them later into rail lights
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, August 11, 2009 - 11:05 PM UTC
Continued with the crane scratch building, after 15 hours of work some progress here, Milliput used for the pipe bends, to thick arm connection to the head and for sculpting the half sphere on the top of the head. Another work done on the valve and its base. All the split pipe rings mounted on the crane body and the turning stops as well.
Thanks for looking
Libor
Thanks for looking
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, August 12, 2009 - 05:44 AM UTC
Pipes cut and cleaned, the head top as well, all ready for another detailing. Valve glued together, for the wheel I will use spare one here (upside down on the picture
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, August 12, 2009 - 08:09 AM UTC
My work on the crane head is going very slow, it is quiet complicated design, and I want precise result. Empty space within will be filled and worked to final appearance, also edges are to be fixed with thin putty and perfectly rounded.
Thanks for looking
Libor
Thanks for looking
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Saturday, August 15, 2009 - 09:41 PM UTC
Lower part of the crane head finished, One kerosene lamp done, for the other one I will make resin casting. The pictures are very poor quality today.
Libor
Libor
jba
KitMaker: 1,845 posts
Armorama: 777 posts
Posted: Saturday, August 15, 2009 - 10:27 PM UTC
I have been following your threads since that wagon brake and man, how do I love your way of scratchbuilding things, you really talk to the ear of the plastic do you?
really great, keep on
Removed by original poster on 08/16/09 - 12:05:37 (GMT).
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Sunday, August 16, 2009 - 10:06 AM UTC
Thank you, jba,
your kind comment is much appreciated. This build actually brings lot of fun, but there are still things about my work I have to improve
I have a few very special plans for near future and I hope they will be really cracking
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, August 18, 2009 - 06:34 AM UTC
I have started the chain winch box. Complicated head top flanges will be cut out of plastic sheet first, and then modified to get final appearance close to the original.
Thanks for looking
Libor
Thanks for looking
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Tuesday, August 18, 2009 - 11:36 PM UTC
Small progress made, everything seems to be all right , so parts can be glued together, and the screws added. Then surfacer coat and final sanding and polishing.
Thanks for looking
Libor
Thanks for looking
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, August 19, 2009 - 04:07 AM UTC
All the screw added and arm pipe glued back.
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Wednesday, August 19, 2009 - 09:33 AM UTC
And one more today, now I have finished the top of the head, where an anchor for tension rope is mounted.
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Thursday, August 20, 2009 - 10:54 PM UTC
Mounting for the chain winch finished
Libor
Libor
Gorizont
KitMaker: 1,462 posts
Armorama: 1,289 posts
Posted: Thursday, August 20, 2009 - 11:41 PM UTC
For these fine-detailed parts one need patience. I don´t have this.
Looks very good, to see the progress!
greetings...
Soeren
greetings...
Soeren
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Friday, August 21, 2009 - 04:39 AM UTC
Thanks,Soeren,this is not as dificult as it looks like. Harder things coming up with my BR 86 soon.
Libor
Libor
CaptSuperCow
KitMaker: 15 posts
Armorama: 13 posts
Posted: Friday, August 21, 2009 - 02:18 PM UTC
I've been watching this build for awhile now and I must say it's my favorite! So much detail and custom build is great. I can't wait to see more progress!
Good Luck to you and keep up the outstanding work!
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Saturday, August 22, 2009 - 03:25 AM UTC
Thank you,Michael,your kind words are much appreciated.
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Saturday, August 22, 2009 - 09:30 AM UTC
A pin added on pipe bend, where the extended pipe will be hung. That will be also used as the anchor for both tension ropes. Two split rings for the kerosene lamps added as well.
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Saturday, August 22, 2009 - 09:46 PM UTC
Elbow pipe completed on the extended pipe and split pipe ring added to connect filling nozzle and tension rope.
Libor
Libor
Posted: Saturday, August 22, 2009 - 11:29 PM UTC
Hi Liobor,
really class work.
Al
really class work.
Al
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Sunday, August 23, 2009 - 09:10 AM UTC
Thank you, Alan. No progress today, however my work on the crane is getting over and I will return back to dio soon.
Libor
Libor
grave_digger
KitMaker: 952 posts
Armorama: 834 posts
Posted: Monday, August 24, 2009 - 02:51 AM UTC
The filling nozzle added, tiny wire will be used later to connect opposite foots.
Libor
Libor
