Nice to see you there too Primož! Only 2 weeks to go yet
You are pretty right Scott, but those were halfway pics, and I don't know how to use my airbrush.
Btw, I want to thank you for your excellent SBS, because my Premi Air G35 works tremendously well despite having a terrible old compressor whose air flow I can't control.
Hi Nico! happy to have you following the thread too
Hi Steve. Most of those paints I bought there:
http://www.oupsmodel.com/index.php?cPath=20_104_256
good French mail order service, but very recently a friend gave a tip for those who are apparently very reliable and cheap:
http://www.ericyymodel.com/
The real problem I see fro figure modellers like you is that I found out they worked best with an airbrush. BUT, a weird property of those is that they sort of never set -if you put a bit of solvent over the paint, it dilutes again. Which means you can use them a bit like oils on shadows.. I tried only in places that were semi hidden, but it looked like the trick is done. So sure really great, but be cautious when using them for a knight's armour for instance.
I didn't find any real SBS about using them, and the only own I found (a French airy guy), was quite inexact concerning the properties of the paint.
This however helped me:
http://codyscoop.com/ht-paint.html
Libor "short modelling life"?!! Looks like you fell in it when you were born
A neat little model that Bronco car, good luck to you
Claude I hoped neither you, nor Carlos, nor Guy, nor Alex, nor anybody that consider buildings seriously would actually notice that one but I was wrong obviously
Matthew you have the gift for foreseeing things as indeed the ball turret will be outside and if you calculate the angle of the light from the pics below you can mostly see which position compared to the hull that one will be
let's finish the airbrush job now:
Applying the silver paint on the high highlights
leave the rear right in the darkness
Whats' the word already "rub and buff"? anyway, stroking the metal with a brush makes the bump popping out
next step will be weathering the thing..
