Hi Martyn thanks and nice to see you here too!
hey jaymes you are pretty right, i did that over a few days time, color correcting again and again until I was more or less happy with the result
Aha Thanks Seb
Good luck with the little one! In july that was just a teaser
hey Jelger, either tomorrow or wednesday I am going to post completed pics, the end is just around the corner now
You nailed it Paul, That's VERY hard to get the right texture for foam and I have been indeed hesitating a lot for it.. But in the end I made something which i think is okay -until I find a better way that's it!
Thank you Garth, it all comes from reading a paper when i was 15, about Sheperd Paine, it was written that he was "famous for his atmospheres", that sort of set the path for the next 25 years
As for the foam it worked like below..
Thanks james, I hope it works as well as your enthusiasm tells, it's appreciated
Yep Paul (again). i think the worse is that the hole in the cockpit as well as the 2 missing plexiglass bits (blown up from the shock?) are taken from A to Z from a real picture. The guy who wrote the poem was in the US Air Force too.
Salut Claude, uh no, no sea. Come on that would indeed be pretty ugly for sea
Just foam, dirtier and shaped in small blots, the texture is quite different more on that just now.
despite more or less managing to get the colour okay, i was still not very happy with the texture, it really looked "acrylic gel", this is why i got the idea of actually mixing it with Andrea microballons (that stuff that is sold to make snow)
Here I am using this stuff on a big run off to put a bit of failed photoetch that I used as rubble near the plane
After a bit of hesitation on where to put it, I finally made my mind to add canopy, Browning and those great GrumpyOldMan full bullets in some empty corner.. (warning, I have been lighting up the pic pretty much)
While the spent cartridges I put close to the plane itself, just like they just fell down from the burning carcass.
let's be clear this is now mostly completed, just one hour to add some shadows on the foam, a bit of colour correction here and there, and I will post the final pictures tomorrow
BUT, just one thing about the base. What to use? if I want to play what I am not, i am going to buy a 4 inches high wooden base, and will write the poem on it in golden letters
But I am not sure if I really care that people get the thing, they can think it's a Gundam for what i care. so that will just be a small wooden frame bought in a DIY store
