Hi Guys,
A bit more progress, well 3 steps forward and 2 steps back
I filled down half of the front wall of the engine and then attached the kit firewall in it's place ensuring that it reached the top opf the upper hull. I need these parts to move as one otherwise I will have to grow another hand. In order to make things a bit easier I hope, I also smoothed the edges of both pieces to allow them to move freely once inside the hull.
There are measurements from the front of the armour to the fire wall but that wasn't much help as I haven't fitted that part yet,
Anyway from the front of the floor to where the firewall should be I recon it is 94mm and I marked a spot on the floor accordingly.
This has some advantages and some disadvantages. I should be able to build the part and slot the whole lot in. but by smothing the sides to allow easy movement to correctly place the part when ready I will have a small gap either side. Filling them hopefully won't be too much of a problem!
The firewall also sits slightly further back than the end of the part on the RHS, and this meant that I had to alter the length of my cooling system and make a small infill to cover the gap. This is covered on the LHS but not the RHS.
Next I looked at the lower turret mounting with a view to building the basket as Chris suggested. This has small groves to fit into the turret and these will need a light sand down. Don't think they are flash and ut them off!!
On the underside of the turret ring there appears to be a bit of moulding spillage and this needed cleaned up to allow the ring to fit the turret housing and I'm working on cleaning that up at the moment. See 2nd pic.
With a little patience and fair bit of sanding this will slot into the housing correctly.
AL
