Hi Mike,
Yes, looking at the patttern of them and the rather untidy one at that, I think they are the left overs from the smoke dischargers too. Thanks for your thoughts.
I'll prbably be proved worng but I can live with it.
Fitted the front hatches. Don't know if this was a good move at this stage, but easier to work with. The front two have additional tiny grab handles to attach, kit part E18 and all 4 have the PE part G4 to add as well.
There was a slight gap between the upper hull and the front armoured plate and rather than fill that later, I've added a thin strip of plastic to fill this out.
The AFV Club side intakes tend to bend inwards in the centre. I don't kow if anyone else found that. The only way I can think of getting the to square up is to use the kit part E12 which is rather ugly. At the moment I've added some left over PE grills I had, not sure about them though, as the overhang a bit given the inward bend.
This is my home fix for the back grills, having cut down parts B23 and B24.
On the finish I had thought about adding part of the deep wading kit, but this would really be a waste of a kit, so I'm probably going to finish it pretty much as per the C Sqn picture on page 78 Mr C's Tanks. If I was to build an earlier Mk I or Mk II to match I could split the kit between the two but that is perhaps something for the future, I'll concnetrate on getting this one buildt first.
I'll need to mix up some sort of green/blue for the engine as per some of the pictures I've seen. This I hope will make it stand up and out of the hatches a bit more, so some experimentation needed on the paint front.
Al
