Time to get cracking on this one. Weather is nasty out so I've had a couple good days inside to build. For a refresher, I'm building HobbyBoss' 1/35 RSOV. I picked it because it's a desert vehicle that is painted black.
Starting off with the engine, which won't be seen. This is a very nice engine out of the box.
On to the frame. Each frame arm composed of two lengths that are sandwiched together.
Cross-members added. The basic frame went together well and required very minimal adjustment to make it all square.
Suspension components added.
Differentials and drive shafts. Instructions were a bit vague on the some of this. I left the transfer case loose and should find its placement when I combine the frame to the engine.
Differentials went on perfect.
Sway bars, roll bars, traction bars, and bracing all added. It gets a bit fiddly here but considering the small pieces the assembly was bang-on.
And that's where I am at with that one.
