Some nice work.
Been a bit since my last update.
Upper hull assembly. Hatches, fittings, etc.
More upper hull details. Guard for the driver, grab handles, etc. I hate to skim over these like that but it's all pretty straightforward assembly.
More upper hull. You can see the PE hinges and exhaust. The exhaust went together really well. I really expected the PE to put up a fight but it fit together quite nice.
I went ahead and painted the lower hull. It's something I've been doing more of late for AFVs. Not show are the wheel rims. I painted them so I could then add the vinyl tires.
While that dried, I turned my attentions to plumbing the crane. Again, it went together much better than I expected. I think the lines are a bit thick.
Rear assembly.
Added the exhaust and PE grills.
I jumped ahead a bit with assembly and base paint. The Final assembled pictures were a bit too blurry. The headlight and mirror assemblies are provided with PE options. I went with the styrene versions. Also, the jerry cans are given with the option of using PE mounts. However, Trumpy wants you to sand off the molded on straps and mounts from the cans. They should have included three bare jerrycans. I went with the styrene, unalterred versions. The PE went in to the spares.
The tires were ho-hum but not that bad. I just popped them in place so if I decide to replace them I can.
And here we have weathered and decals added. I had some pictures of it just weathered but it just seemed redundant to post them and then pictures of the decals added. The markings are more labels for tie downs and lift points than anything else.
I drybrushed using Tamiya Field Gray, just to let let some of the under coat of green poke through. I did a very light wash. The wheel were drybrushed with a coat of Tamiya Dark Gray. Mirrors and lights were painted. The periscopes appear darker than they really are. They usually appear bluer so this is an improvement I guess.
And there she is...so I'm declaring her done. At some point I'll probably do something with her. I'll add stowage to her then and give her a proper dusting.
The kit really was a breeze to build. A huge improvement over the old Italeri kits. I'll probably add the Air Defense and Anti-tank versions later on.
I'll get a couple pics in to the gallery.
