As far as the kit goes, it was the Panther Night Fighting tank from DML with the some PE screens, Cavalier Zimm, and some Tamiya one piece tracks.
Hi,
Beautiful Panther, Miloslav. What kind of paint you used to reproduce color Dunkelgelb?
Paweł
This kit is friggin awful. The stamp on the bottom of the hull says 1969...no wonder it only cost me 10 bucks! The fit is really bad and some bits of the tank look either too big or too small. I put down Olive Drab over Desert Yellow for the camo. I went to 'stripey' and not 'blotchy' enough. Next time I will certainly trace the camo pattern before I spray. Still a bit of weathering to do and some dust to be added to the lower hull and running gear.
Can I use the ambush camo, on this kit? I believe the dates line up, but am having difficulty locating a photo of a steel wheeled tank, with this pattern.
You're obviously free to believe what you like but Jentz (PT 5-170) reports Fgst Nr indicate only 24 confirmed. Do your sources have that degree of credibility?
The steel wheel series appears to be exclusively a MAN series, built in September.
