Hi guys - only time for a really quick post today! racing during lunch break -
You'll see a few more figures - essentially built a couple of guys each night last week, then production line painting all day Saturday!! I thought I'd go blind!!! anyway, have a look:
Above are most of them. In total I added 8 new figures:
The pics tell the story! the one obvious point: I used a few mfgrs here - and when you do that - you get: different size guys. Different: EVERYTHING! weapons, gear, you name it, almost everything is at least slightly...if I were just doing a detailed study of the soldiers, they would each be redone! as I'm not, they are staying as is. Some of the differences have more to do with being close, but not exactly the same - I'm hoping that as they are scattered about and in fairly dynamic poses, it really won't be all that obvious.
And now:
This type of pic seems to be fairly popular - the whole package image! Anyway, this will eventually get built into a Bradley M6 Linebacker. This version had four stingers mounted on board, instead of the TOW system. This will require some scratch work, but not really all that much.
The bigger challenge is turning out to be that the Academy base kit is fairly simple; it doesn't have too many parts, and those it does have are a bit chunky and the assemblies are fine. All of this ok - as it represents the correct vintage Bradley for around 2004.
Where it's getting interesting so far comes from the Voyager "basic" upgrade kit - Man! that's got some heavy duty etch work headache inducing "moments"!! so far several hinges, latches, "curves" you name it and I'm nowhere near done! hopefully will result in a cool build!!
Ok, that's all for now! back to the real job!
Nick
