Hello -
well, I've a had a fairly productive last few days - working away on the building. It's never clear how this will all come together. So far, as you might suspect, some things worked out just fine - others less so....
First, after paint, the building is assembled and glued! as for the product placement, ironically, I use mostly Vallejo Paints....I'll include more of their stuff next time! haha - take a look:
As you can see above - lots of weight to compress this during the "big glue" - haha! just a coincidence that the pic of the SF Ferry Building is in the background - the clock tower on that building is much nicer than my tower of spray glue -
and the results:
so, this worked out pretty well - you can see some spackle to fill the gap between the floors, really, no big deal.
This closeup sets the tone for what I'll be doing for the debris, looking into the building - here's a newsflash: It's very slow going!!!!
The two below look at the entry area - this is still not done, and is not glued in yet:
Sorry about the bad pics! but, you get the point - there's more going on there than what you can see above, and, it's still not done!! more debris, and of course, eventually, fine crushed glass....
and, onto more S-L-O-W work: making concrete debris:
Above is only a fraction of the concrete and CMU debris I've made....it looks pretty good when done....but, it sure takes time!!! I'll eventually make, and then crack plaster for more debris - - I just hate the mess and lack of predictability with plaster!!!! - I'm not sure this method is much better though, in terms of the general level of model building irritation!
But, the results, pre-more debris, any pigment, ground effects etc, etc, etc...and more etc's:
And, there you have it. At this point, it would be ridiculous to list all of the things I'm going to add, subtract, repaint, fix, etc...so I wont!
thanks for checking it out!!
Nick
