I painted the track dark gray. I have been using a rattle can dark gray primer for my base coat on tracks. It gives it a texture. Once dry. I dry-brushed the tracks steel, being a bit heavier on the guide-teeth. I'll give them a wash later and dust them.
Three shots of the tracks...two for the thrown side, showing front and rear.
Radiators and fans. Painted them red-oxide, though they look more brownish. I picked out the fan blade edges with steel.
Radiators mounted. I had been debating on adding an engine. I was actually a bit surprised the kit didn't come with one. I think the cross-arms for the sponsons might be why they didn't include one....the rear one is in the way of the engine tub.
I had an engine in the spares. It looks like an old Italeri Panther engine. The fit between the radiators was really tight and needed some "persuading" to fit. A little sanding it was fine.
The engine was painted dark gray with details picked out with a lighter gray and then steel. The air filter covers were painted white. The hose was black with silver fittings. The engine compartment was painted red-oxide. It's a pretty simple engine. I didn't want to use my last Tamiya engine set on this one. Except for the covers, you really cannot see much of it.
Periscopes and periscope covers added to the front. The rear engine cover, circular vents, and other rear details added.
And that's where I am right now. Assembly is starting down the home stretch.
