Sidebar update on the Mk 23 truck:Recently ordered two kits of the 23 at the same time to save on shipping but only received one - that in itself is a kick in the pants and the wallet!
Having now looked at the one kit I can share that on the MK 23 only the front axle steers! However, the TAK-4 rear non-steering suspension units are constructed using the same parts (more of less) as the forward steering unit and it should not be too difficult at all to modify the rear axles to add the steering equipment.
A single kit will give you three axle suspension units, two steering gearboxes,
(both needed for the front axle,) two simple differentials and one pass-through differential.
Two kits will give you more than enough parts to build either the four axle 8x8 Mk 23 LHS steering & suspension OR the electric hybrid 8x8 HEMTT A3!
Just an F.Y.I. - Overall this model has excellent detail and style. It is a shame to waste the cab and chassis on a conversion. It is going to be extremely difficult to talk myself into building the HEMTT A3 rather than the 16.5 ton, Mk 23 LHS!
