Dustin & Taylor - It looks like I am IN for the 16.5 ton LHS. Dawg gone it! - if I had just received BOTH kits I would be cutting frame parts right now! (I might start on it tonight anyway! The first and second axles are stock right out of the Trumpeter kit anyway) - trouble is right off the bat I need to extend the frame between the rear of the cab and the #2 axle and for that I need that second kit!
Chris - I am somewhat interested in adding the AIRCO/Red Dot A/C unit to my HEMTT but so far I have not found any reference as to how the outside condenser mounts. Also that Pro-Art kit is seriously pricey so I am thinking I will scratch both the inside and outside parts of the unit using HO diesel locomotive cooling fan grills for the condenser unit.
Posted: Wednesday, November 09, 2016 - 03:07 AM UTC
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Wednesday, November 09, 2016 - 03:48 AM UTC
You may not need to. Mike "MikeyBugs95" Goldberg has apparently stated on the Red Dot units. He posted the following in his "Looking for ideas for what to 3D Print" thread:
"I've also started drawing up a Red Dot R-2400-0 A/C unit. The wall unit should be done soon and I'll then get started on the condenser unit."
Posted: Wednesday, November 09, 2016 - 03:51 AM UTC
Gino I remember now that I had noticed his statement about the AIRCO. Would you perhaps have any reference on how that older twin fan outside condenser unit mounted to the HEMTT cab?
Posted: Wednesday, November 09, 2016 - 04:15 AM UTC
Here is the TM for HEMTT A/C units. It looks like it is the small box on the left side fender in front of the air cleaner. This TM is for a built-in system though, not the Red Dot wall box.
https://az774353.vo.msecnd.net/library/TM/HEMTT/TB-9-2320-279-13-1/TB-9-2320-279-13-1.pdf
Looks like the same unit on this one which most likely has the Red Dot unit.
Posted: Wednesday, November 09, 2016 - 06:23 AM UTC
Way back on page 11 I was asking about just such an item.
_________________________________________________________________________________
What is this?
I am going to hazard a guess and say it might be the cab air conditioning condenser!
Can anyone confirm?
Original un-cropped photo credited to TacAir Publications and Michael Benolkin - Used here for discussion purposes ONLY.
What is this?
Can anyone confirm?
Posted: Wednesday, November 09, 2016 - 06:30 AM UTC
Yup, that's exactly what it is. That is the same type shown in the TM and on "Rolling Thunder" above.
Posted: Wednesday, November 09, 2016 - 06:39 AM UTC
Looks like the die is cast:
I started putting the Mk 23 frame together tonight and I cut the riser boards off the frame that would support the load box so it is now for sure heading in the direction of becoming a 16.5 ton LHS 8x8.
If I can, I intend to wait for the Trumpeter HEMTT LHS to hit the market. I may get a slightly better LHS system plus the X-frame container handler and a much improved HEMTT truck for some future project.
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Wednesday, November 09, 2016 - 09:27 AM UTC
So sweet! I can't wait to see this build also!
heliman
KitMaker: 702 posts
Armorama: 604 posts
Posted: Wednesday, November 09, 2016 - 07:06 PM UTC
The MK 23 is a great kit to start different conversions from, can't wait to see your take on the lhs.
I built the wrecker variant MK 36 "Medusa " awhile back on here, prolly my favorite model I've done .
Posted: Wednesday, November 09, 2016 - 08:32 PM UTC
Does any one have a lead on the Tech Manual for the Mk 23 in general or on the 16.5 ton LHS specifically? References on these vehicles seems to be few and far between, likewise photographs.
Thirian24
Posted: Wednesday, November 09, 2016 - 09:40 PM UTC
Posted: Wednesday, November 09, 2016 - 09:52 PM UTC
Taylornic
KitMaker: 337 posts
Armorama: 332 posts
Posted: Thursday, November 10, 2016 - 03:28 AM UTC
Good luck, and I WILL be following along on the new build as well.
Posted: Thursday, November 10, 2016 - 09:52 PM UTC
Posted: Friday, November 11, 2016 - 01:53 AM UTC
The seats in the Italeri HEMTT are correct for an older vehicle. The taller seats were introduced in the late '90s across all vehicles as the lower seats were causing back issues. But you are correct that for an M1120, it would most likely have the taller seats.
Posted: Saturday, November 12, 2016 - 08:37 PM UTC
Just finished a Sunday pancake breakfast with my young grandson. I think maple syrup has some of the same physical properties as Super Glue. It runs up your fork and glues your fingers together.
Bigred69
KitMaker: 290 posts
Armorama: 249 posts
Posted: Sunday, November 13, 2016 - 01:58 AM UTC
I hope you enjoyed the Pancake breakfast!
Posted: Sunday, November 13, 2016 - 11:56 AM UTC
Thought you might like to see how the brakes turned out.
Cheers Rob.
Cheers Rob.
M4A1Sherman
KitMaker: 4,403 posts
Armorama: 4,078 posts
Posted: Sunday, November 13, 2016 - 04:00 PM UTC
Maple Syrup manufacturers, both corporate and private entrepreneurs, got that idea from Continental Army Mil.Spec 00013-and-a-half MS/S-G I & Rev.I & Ia, (2-1-1777, 2-2-1777), way back in General George Washington's day... This spec states the following:
"Maple Syrup", (MS) (ref. Mil. Spec. 00013-and-a-half MS/S-G I & Rev.II) Shall forthwith, (2-1-1777), containe Alchemifts' component S-G (Super-Glue), for the expreffe purpofe, to wit, of binding qualitief, with which the Human Fingerf of the Continental Army, fhall be binded inexorably, to wit once againe, to: Knivef, Forkef, Spoonef and other Sundry Utenfilef... (See Operational Manualf, Ufeage of Eating & Sundry Utenfilef, Mil.Spec. 00001E, Rev.I and Ia)
Beautiful work, Mike!
Posted: Sunday, November 13, 2016 - 06:22 PM UTC
Thought you might like to see how the brakes turned out.![]()
Cheers Rob.
The brake cylinders look great. Are they cast resin or 3D printed?
Posted: Sunday, November 13, 2016 - 06:40 PM UTC
They are resin copies of the Trumpeter rear brakes.
Cheers Rob.
Cheers Rob.
Posted: Sunday, November 13, 2016 - 07:34 PM UTC
Dennis - that's funny
Rob - the brakes turned out nice. You should be able to sell some of them if you put the offer out there. Again I need to get into resin casting!
M4A1Sherman
Posted: Sunday, November 13, 2016 - 11:00 PM UTC
Thanks, Mike! Thought you'd get a kick out of it!
Gino & Rob- I've been following along with your builds, too!
EXCELLENT WORK by ALL of you guys!!!
Frenchy
KitMaker: 12,719 posts
Armorama: 12,507 posts
Posted: Tuesday, November 15, 2016 - 01:41 PM UTC
Hi Mike
Maybe it's too late for your project, but I've just came some detail pics of a M1075A1 and a M1120A4 on Flickr (mostly chassis & interior views) that may be new to you :
https://www.flickr.com/photos/truckexposure/albums/72157657869859070
H.P.
H.P.
Posted: Tuesday, November 15, 2016 - 08:23 PM UTC
H.P. - Very nice detail shots towards the end of the post of a HEMTT A1 PLS!
