Mark. Yes the wood looks fantastic. It will pop some life into the finished build... mine will be grey all over except the ammo rounds... so a 'leetle beet' of color in it.
Bob. Do you have shares in Evergreen??
Sorry to see you had to redo, but the result is looking really impressive.
Well time to put some pics where the mouth is... so to speak. These were taken on the weekend but haven't had much time to upload.
First up spent a while filling knock out marks on the inside of the ammo transport module.....then spent a day sanding them all down with a few touch ups. Had to be careful not to loose detail:
Ran out of putty and the LHS only had Tamiya Brand. It dries rock hard and takes a lot to remove.
Also made some progress on the winch assembly. This needed a lot of trimming of flash and for parts to fit. Also some filler needed in places.
Also fitted the front tow mounts. These are from Dragon as the Trumpeter ones left a lot to be desired. The etch ones they provide are over sized and the styrene ones are in two halves split where the locking pin runs through the holes on the mounts. I was over looking at puttying gaps and sanding the components again by this stage.
The image shows where the hull top has had some panels fitted too
Brain went into neutral when I was fitting the bolts to the drive sprocket mounting. I fit them as per the instructions, forgetting all the bolts are for the Ausf E... the Ausf D did not have so many. Have to trim them off and relocate them.
Off on holiday for a few weeks on Saturday, so not much to show for a while. Happy building to everyone in the meantime and see you soon.
